Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-14-2004, 11:48 AM
SAUZA SAUZA is offline
Question 1999 sl2-shift knob
Does anyone know how to remove the gear shift knob off of a 1999 sl2 with automatic transmission? I need to take the console out to change out the fuse block.
Old 01-17-2004, 08:25 PM
VS1400 VS1400 is offline
Re: 1999 sl2-shift knob
If you pull the shifter down into "2" and look at the front of it, you'll see a small slot. Inside is a clip which retains the shifter knob to the shaft. It prys out easily with a small blade screwdriver.
The shifter doesn't have to be removed to remove the center console. The console will pass over it without a problem with shifter in "2".
And for that matter, the instrument panel fuse block can be replaced without removing the console. The easily removeable console extensions at the front of the console should be the only thing necessary to remove.....
Gear selector hard to shift serge_saati Windstar 16 06-05-2009 09:57 PM
1999 SL2 slight transmission leak hakebros SC/SL/SW 1 01-27-2006 08:01 PM
Shift boot to shift knob Toji Cars in General 1 09-13-2004 09:54 AM
2002 SL2 Shifting Issue mhccdc SC/SL/SW 1 02-17-2004 10:56 AM
shift knobs and 4x4 knobs SilverLotus340R Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 12 04-01-2003 09:26 AM
