Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 01-13-2004, 12:40 PM
kevin9333k kevin9333k is offline
Smile Front Axle and Rear Axle Fluid Volume
I want to replace the gear oil (SAE 75W-90) front/rear axle in the Denali 2002 but cannot find the amount needed to refill the front and rear axles once they have been drained. I assume 2 qts but not sure.
Thank you,
Kevin
Old 01-13-2004, 09:34 PM
99ssconv 99ssconv is offline
Front Drive Axle (8.25")
1.66 liters
1.75 quarts
Rear Drive Axle (8.6")
2.28 liters
2.41 quarts
Front Axle (S4WD)
SAE 80W-90 Axle Lubricant GM P/N 1052271, Canadian P/N 10953455 or equivalent.
Front Axle (F4WD)
SAE 75W-90 Synthetic Axle Lubricant GM P/N 12378261, Canadian P/N 10953455 or equivalent meeting GM Specification 9986115.
Rear Axle
The Selectable Four Wheel Drive (S4WD) Front Axle consist of the following components:
Differential Carrier Housing
Differential Assembly
Output Shafts (Left and Right Side)
Inner Axle Shaft Housing
Inner Axle Shaft (Right Side)
Clutch Fork
Clutch Fork Sleeve
Electric Motor Actuator
The front axle on Selectable Four Wheel Drive model vehicles uses a central disconnect feature in order to engage and disengage the front axle. When the driver engages the 4WD system, the Transfer Case Control Module sends a signal to the electric motor actuator to energize and extend the plunger inside. The extended plunger moves the clutch fork and clutch fork sleeve across the inner axle shaft and the clutch fork shaft and locks the two shafts together. The locking of the two shafts allows the axle to operate in the same manner as a semi-floating rear axle. A propeller shaft connects the transfer case to the front axle. The differential carrier assembly uses a conventional ring and pinion gear set to transmit the driving force of the engine to the wheels. The open differential allows the wheels to turn at different rates of speed while the axle continues to transmit the driving force. This prevents tire scuffing when going around corners and premature wear on internal axle parts. The ring and pinion set and the differential are contained within the carrier. The axle identification number is located on top of the differential carrier assembly or on a label on the bottom of the right half of differential carrier assembly. The drive axles are completely flexible assemblies consisting of inner and outer constant velocity CV joints protected by thermoplastic boots and connected by a wheel drive shaft.
The Full-Time Four Wheel Drive (F4WD) Front Axle consist of the following components:
Output Shaft (Left Side)
The front axle on Full-Time Four Wheel Drive model vehicles does not have a central disconnect feature in order to engage and disengage the front axle. The left and right axle shafts are connected directly to the differential case assembly. This allows the axle shafts and the propeller shaft to spin continuously. The transfer case controls the amount of torque applied to the front axle. The remaining components are the same as the selectable four wheel drive axle.
Old 02-09-2004, 06:44 PM
Re: Front Axle and Rear Axle Fluid Volume
Thank you for your response.
Kevin
1.66 liters
1.75 quarts
2.28 liters
2.41 quarts
Front Axle (S4WD)
Front Axle (F4WD)
Rear Axle
Clutch Fork
Clutch Fork Sleeve
Old 09-20-2004, 10:57 PM
the blur the blur is offline
on the 2003 Denali, what size ring gear does it have?
9.75" or other.
seems different rears take different fluid.
the updated part# for the synthetic fluid is 89021677
Old 11-06-2009, 10:57 AM
Jokerdelight Jokerdelight is offline
Hello,
I have a Yukon Denali 2003.
I do not have the selector to disengage the four wheel drive.
I was wondering what does it take to modify my truck to add this feature besides the selector in the dashboard.
Do I need to change the complete differential to have the plunger? Or is it possible to add it to the existing one?
Thank you
J-F
Oil capacity of GTS rear axle 2006GTS GTRA / GTWS / GTS 2 10-01-2010 07:46 PM
Transmission fluid and rear end fluid drichers Tahoe 1 06-27-2006 09:51 PM
Front Axle and Transfer Case Fluid Capacity fire24resque Silverado 1 03-07-2006 02:27 AM
"Tink" noise when taking off and rear axle moves on initial accel YtseJam454 Wrangler 10 10-26-2005 09:19 AM
Front Dif and Transfer case fluid change...is it difficult ? Alexxn 00 Si Blazer 2 04-18-2004 07:03 PM
