Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 08-01-2005, 04:14 PM
YtseJam454's Avatar
YtseJam454 YtseJam454 is offline
"Tink" noise when taking off and rear axle moves on initial accel
04 Wrangler 4.0L MT when you let the clutch out and begin to accelerate there is a tink noise. It hapenns in forward or reverse and is annoying. Anyone else???
Old 08-02-2005, 08:51 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
U joint
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 08-03-2005, 09:52 PM
YtseJam454's Avatar
Re:
Originally Posted by slacker_53
U joint
Not U-Joints. I'm wondering if anyone else has this bizarre noise. It's very hard to pinpoint.
Old 08-06-2005, 09:07 AM
Saxonwolf's Avatar
Saxonwolf Saxonwolf is offline
I have the exact same problem, and youre right it isnt the U joint. Anyone have any ideas?
Old 08-08-2005, 12:01 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: "Tink" noise when taking off and rear axle moves on initial accel
I knew a guy that had a bad stud on one of his wheels, made a -tink- noise. Worth a check. You should be able to isolate the area with listener outside the vehicle.
Old 08-08-2005, 12:56 PM
wilwith1l's Avatar
wilwith1l wilwith1l is offline
Made made the same noise, then 3 studs broke off, and my wheel fell off(it's an 05). No it is doing it again, but I have checked the studs. It is from the front.
Old 08-08-2005, 09:32 PM
YtseJam454's Avatar
It almost sounds like it's coming from the pinion area of the rear end. It only does it with the suspension loaded so it's hard to lay under there and pinpoint it. Definitely not the wheel studs
Old 08-09-2005, 07:26 AM
Could it be a loose bolt in the axle locating arms, or the spring where it sits on the axle?
Old 10-18-2005, 12:07 PM
Eddie05Wrangler Eddie05Wrangler is offline
Same Problem. Anyone pinpoint this yet? I'm going out to rotate the tires, I'll check to the studs.
Old 10-18-2005, 02:30 PM
JDPascal JDPascal is offline
A "dry" slipyoke will make sounds when it has to move slightly under load.
Might apply to the front slip yoke but the rear slip yoke is usually at the transmission. Try a couple of pumps of grease and see if it changes things.
Check the slip yoke splines for wear too.
JD
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
Old 10-26-2005, 09:19 AM
Any luck finding the cause?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
