Old 01-13-2004, 11:08 AM
planetmf planetmf is offline
Send a message via AIM to planetmf Send a message via MSN to planetmf Send a message via Yahoo to planetmf
Clutch gone?
Can anyone confirm this? Pulled up to guard shack at work, clutch pedal seemed a little funny, went to pull away and couldn't get the car into gear. Had to push it off to the side, shut it off, put it in gear, start it, and drive it to the parking lot. Can't put into gear with or without the clutch, pedal pretty stiff. It's shot, right? 1992, 3cyl, 5 speed.
Old 01-15-2004, 12:03 AM
geozukigti geozukigti is offline
Could be one of a few things, not the clutch.
1. Blown input shaft bearing
2. Bent shift linkage
3. Stripped synchro
4. Flywheel came loose
5. Bent input shaft
6. FUBAR'd tranny.
I'd check the shift linkage first. If not, take off the inspection plate on the bottom of the tranny, and see if you can get the flywheel to flop around(checking for bearing play) If there's no play, time to pull the tranny, and see if everything's tight on the flywheel.
Old 01-15-2004, 09:46 AM
Thanks a lot for the list! I had it brought to a shop (it's below zero here) so we'll see what the diagnosis is. I'll let you know, thanks again.
Old 01-16-2004, 11:24 PM
o yeah, i 4got one thing. Could be the motor mount too. If the engine's sittin funny, it'll never go into gear.
Installing a clutch pedal assembly towelie Ranger | Courier 1 02-15-2009 07:18 PM
Is my clutch gone? 1999 w/100k mi blumr2 4Runner/GX470 1 12-05-2005 09:09 PM
Clutch gone, sell it or scrap it? bdzb1234 Rodeo | Passport | MU 2 11-07-2005 08:20 PM
Clutch gone out??? buddinbuddin Ranger | Courier 6 01-12-2004 11:33 AM
clutch gone bad? need help tfish Accord/TSX/Accord Hybrid 1 10-06-2002 05:05 PM
