Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 01-13-2004, 10:13 AM
dkrace67 dkrace67 is offline
Unauthorized Gear Change?
I have had an unusual "problem/occurance" with my '98 323is where intermittantly it will kick itself out of gear. This occurs very randomly and only happens in first gear. Most likely scenario will be I pull up to a stop, put the car in neutral for some period of time, then put it in first and start to let the clutch out. As I'm doing that the gear shifter will violently pop out of gear and make a loud (soil your pants loud) clunk and I'll be in neutral. Again, it is intermittant and in order to avoid it (with some repeatability) I will cycle the tranny in and out of first several times before attempting to let the clutch out. This seems to avoid help and I haven't had it happen if I cycle it in and out of gear. Any ideas as to what is happening? Do I need to adjust the clutch? Is it time to replace the clutch (110,000miles)? Help! I'm running out of underwear!
Old 01-14-2004, 10:00 AM
Stephen 325TDS Stephen 325TDS is offline
Re: Unauthorized Gear Change?
If you don't have problems changing between other gears, then it would point to the gearbox itself! Sorry.
Stephen
Rough Gear Change at 40-60mph kohokoho Camry/Camry Hybrid/Vista 2 03-19-2004 11:45 AM
Is this a good price for a gear change "kit"? hot_red_z28 Camaro Discussions 6 01-06-2004 10:12 PM
CLICK! noise after gears changing ricebooy Accord/TSX/Accord Hybrid 6 08-17-2003 02:06 AM
gearing change? Aythya Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 04-11-2002 09:01 AM
Gear Changing.... [TWUBLE] General Discussion 34 01-24-2002 07:29 PM
