Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-18-2004, 06:09 PM
kohokoho kohokoho is offline
Rough Gear Change at 40-60mph
I have recently noticed a rough transmission change at around 40-60mph in my 88 Camry (automatic transmission) with 163K. As some fellow users suggested in other threads, I tried easing up on gas when the transmission is rough, but doesn't help much. The ride becomes smooth, of course, after the car picks up speed again. Other than this the car runs incredibly smooth.
Any ideas what the problem might be? Would it be that it's time to change the transmission oil/filter? I don't know the last time it was changed, i got this car when it had 158 K. I have, however, changed the engine oil every 3000 miles.
Old 03-18-2004, 09:20 PM
Joe W Joe W is offline
Re: Rough Gear Change at 40-60mph
It would be a good idea to service the trans as this is a maintence item anyway.It could be when it shifts into overdrive at this speed, in which case the fluid is probably not the culprit.Try turning the O/D off and see if that shift is still rough.
Old 03-19-2004, 11:45 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Also, another addition to what Joe has said...You probably should start changing the fluid at a certain interval also you should check the filter and clean the strainer, and this should eliminate the problem.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
2000 Blazer - rough gear transitions theranger969 Problem Diagnosis 6 10-17-2006 05:30 PM
90 Marqui, Loss of Power and rough gears lordmcdeath Grand Marquis 4 07-20-2005 11:58 AM
89 SE running rough since changing plug wires...help??? roozter87 Grand Prix 1 02-02-2005 02:17 PM
93 Es300 Rough Gear Shift When Cold, loss of power, acceleration jksc ES300/ES330/Windom 3 07-07-2004 08:40 PM
'89 Supreme running rough after changing O2 sensor pdonis Cutlass Series 3 05-16-2004 08:19 AM
