Old 01-11-2004, 09:56 AM
ToaDady ToaDady is offline
96 3.3l runs......sorta
was cruising at 70mph, when it started dropping cylinders. made it off the road , and it died. It would restart after quite a bit of cranking, but would only run on 2-3 cyls. let it sit a min. then restarted it, sounded good, would onlyrun 25 mph, died again and wouldn't restart, waited a bit , and it restarted running only on 2-3 cyls. State trooper pulled up behind me,i let it sit there loping , used trooper's phone to call my dad, when i came back it was running fine, sat there for 20 min running like new. when dad showed up he followed me and it ran great for about 15 miles. then it started all over again, made it to home loping on few cylinders.....going to check fuel press in a bit, any help ,
sorry if it sounds hard to read, was in a hurry...
Old 01-12-2004, 08:37 PM
gforster gforster is offline
Re: 96 3.3l runs......sorta
check your fuel pump and camshaft position sensor
Old 01-14-2004, 02:25 PM
MADMAX03 MADMAX03 is offline
Have same problem to a "t". Anyone have the answer. HELP.
Old 01-14-2004, 02:44 PM
fuel pressure was only 25psi. idling,rev it up and it dropps 22-23, and stays there until i let it idle again. took the fuel filter off,cut it open, and there was a sliver of twisted metal, so the new pump goes in tonight.
Old 01-14-2004, 03:15 PM
What is good fuel pressure? How much PSI should it be?
Old 01-14-2004, 03:55 PM
most multiport systems need 35-45 psi what i'm reading in a chilton that's for a 93-97 LHS-newyorker with the 3.3l is that it operates around 55psi.without the regulator, and 48 with it hooked up,...BUT the 96 caravan's regulator is on the pump assy in the tank. so i'm shooting for 45 or so.
Old 01-14-2004, 10:14 PM
Sounds like you're on to it toadady. Your right at the pressure supposed to be around 48 25 psi is definetely a problem. Let me know if the new pump fixes it ok?
Geoff
Old 01-15-2004, 08:34 AM
Hey we've got 55psi now,and it drove home , so i think were good to go.
Old 01-15-2004, 11:32 PM
Sounds good thanks for updating us ToaDady
1999 grand caravan se 3.3L HEATER Tyson_baker Caravan | Voyager 4 01-24-2011 03:24 PM
93 grand am se 3.3l running rich bradbennett1981 Grand AM 7 10-22-2007 08:38 AM
'95 Intrepid ES 3.3L Fans run continously SmittyC Intrepid 11 03-28-2005 04:29 PM
1993 Ciera 3.3L Very rough running CBRF Engineer Cutlass Series 1 12-23-2004 10:48 AM
3.3L Caravan runs on 2 cylinders ... Cobra_Sam Caravan | Voyager 2 12-09-2004 09:36 PM
