Old 01-23-2011, 09:42 PM
Tyson_baker Tyson_baker is offline
1999 grand caravan se 3.3L HEATER
OK so I have no heat. What I have done: changed thermostat, changed water pump, flushed radiator, still nothing. I also have done alot of cussing and swearing but that doesnt help either. Any suggestions?
Old 01-23-2011, 09:56 PM
tempfixit tempfixit is offline
Re: 1999 grand caravan se 3.3L HEATER
I assume your heat gauge reads in the normal range when to normal operating temp. Have you checked the new thermostat in boiling water to confirm it is working properly?? Made sure all the air is burbed out of the system. (heater turned on full heat during burbing of air) Checked the heater core hoses to make sure they are close to the same temp by feel.
Old 01-24-2011, 07:06 AM
b1lk1 b1lk1 is offline
If the gauge is reading normal, try flushing the heatercore as well. They can clog up due to lack of maintenance.
Old 01-24-2011, 02:44 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Cussing and swearing no help? I throw tools. Course that never works for me either especially when I spend twenty minutes trying to find it again.
HVAC system working? Try a calibration/self test?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 01-24-2011, 03:24 PM
mikefaster mikefaster is offline
Feel one heater hose and see if it's hot and then see if the other is cold... If that's the case, then the heater core is clogged... I have fixed this numerous times by swapping the heater hoses (they are the same size)... You will usually have heat instantly, if not better heat after running it for a day... There is usually enough hose to swap them and you can leave them swapped... If the weather was warmer, you can put a garden hose on reverse flow and that will usually free it up as well...
If both hoses are cold, then you may have a head gasket seeping, causing pressure build up of carbon monoxide in your cooling system... The gas rises and doesn't allow water to travel up that high... You can try a 7lb radiator cap then...
Sometimes, people just don't properly "bleed" the system when they change the thermostat... Meaning, you may have just needed a thermostat, but you didn't run it long enough without the cap off while viewing/filling the water level... Many people will change thermostats in very cold weather and it seems like the engine "never warms up enough"... The trick is to KEEP running the engine until the fan comes on at least once, without the cap on... If the water wants to keep coming out during this process, you may have a head gasket seeping...
Did it recently overheat or have a cooling system problem???
Mike
1999 Dodge Caravan 3.3L Brakes Locked Ron Redman Caravan | Voyager 5 10-12-2009 11:43 AM
1993 Grand Caravan 3.3L Code 43 CKFord Caravan | Voyager 12 10-28-2005 06:12 PM
How extract p/s pump from '93 Grand Caravan 3.3L? dcd123 Caravan | Voyager 1 06-03-2005 06:53 AM
1992 Dodge grand caravan 3.3L won't start jimsparky Caravan | Voyager 0 02-05-2004 05:21 PM
Tags
1999 , 3.3l , caravan , dodge , heater
