Old 01-11-2004, 07:50 AM
currendiver currendiver is offline
'92 with little heat
Hi;
My '92 GrandAm (3.3l) produces only a moderate amount of heat, and not nearly enough for a cold Canadian winter.... At idle, the air cools down, then gets warm again after RPM's increase. I tried installing a new Thermostat, but no improvement. I even tried placing some insulation between the exhaust pipe, and the thermostat housing, which are close to each other. Anti-freeze levels are high. Can anybody help me? Thank you.
Old 01-11-2004, 11:42 AM
pawn's Avatar
pawn pawn is offline
Banned
Send a message via AIM to pawn Send a message via MSN to pawn Send a message via Yahoo to pawn
how much air is blowing out when you turn it up on high? might be your heater fan...not pushing enough out.
Old 01-11-2004, 11:45 AM
Lots of air coming out, the fan is working good.
Old 01-11-2004, 12:33 PM
pawn's Avatar
Banned
hrmmm, strange...i'll keep in touch...i have to ask someone that would prolly know what the problem is.
Old 01-11-2004, 05:55 PM
Jpit Jpit is offline
Re: '92 with little heat
Maybe your heater core is slightly plugged up. May be time for a flush.
'97 with very little heat KaIIen Jimmy 6 01-18-2011 06:23 PM
little door with little switch? 1990 deville magic8161 Deville 1 04-16-2007 09:01 AM
'92 PA no heat thru vents PBrad Park Avenue 4 11-26-2006 10:17 AM
96 Trans Am with little or NO heat fritcr Camaro Discussions 2 12-22-2005 06:57 PM
96 Astro with little heat L Gregorczyk M Bodies 1 12-29-2003 07:37 PM
