Old 12-28-2003, 10:14 PM
L Gregorczyk L Gregorczyk is offline
96 Astro with little heat
I have a 96 Astro that blows little heat, I've changed the thermostat, back flushed radiator and lines, checked heater core and the blower is working at all speeds.
Old 12-29-2003, 07:37 PM
Twist'n-Wrenches Twist'n-Wrenches is offline
Re: 96 Astro with little heat
You may have the temp flap inside the heater not openning. Are both heater hoses hot going in and out of the heater if they are. Then check the heater temp flap or the vacuum lines on the actuator or the actuator itself. Good luck
