Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-08-2004, 02:27 AM
integRS integRS is offline
Send a message via AIM to integRS
something wrong with fog lights, won't turn on. help plz
hey i installed my fog lights and a problem occurred. so lights mounted
all connections made. except for one thing. the mini-relay thingamabobber connected to the switch has these:
1. ground. 2. switch 3. a random red wire with open tip.
what do i do with the red wire? according to my research, it's supposed to be in "ignition power source" where is that? i never knew that it would be so complex, as to need connections to the ignition. any help would be appreciated. thanks
Old 01-08-2004, 02:40 AM
Re: something wrong with fog lights, won't turn on. help plz
a light bulb turned on and i just realized that the "mini relay" i meant was the harness. sorry about that, i had a mind block
Old 01-08-2004, 09:18 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Hav eyou connected a wire to the battery or a power source yet? It sounds like you have no power to the relay. Check all the connections again and double check the wiring diagram.
Old 01-08-2004, 10:06 PM
Gurgus Gurgus is offline
Does your kit for the fog lights have a light in the switch? If so, that red wire is probably the power source for the light in the switch. Do you have a circuit tester? If you do, find a power source that only works when the ignition is on. Hook that line up to that and Bob is your father(or mother's) brother(read:uncle.)
Old 01-09-2004, 12:35 AM
thanks guys but i figured it out. the red wire from the harness leads to another power source, for me, it was the spliced headlight. now they work even without ignition, cuz headlights get power even with engine off. that's what i wanted. only problem now is i wanna use parking light and fogs only, so tomorrow i'll unsplice, and splice to the side marker light. thanks guys
Old 01-09-2004, 11:49 AM
HondaIntegraXSI HondaIntegraXSI is offline
Send a message via AIM to HondaIntegraXSI
heh, that would look cool.
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
Fog Lights won't turn off dave8105 Rodeo | Passport | MU 3 08-01-2005 06:47 PM
FOG lights won't turn off... latsirk Alero 0 06-14-2005 10:13 AM
2004 have my fog lights automcatically turn on? dmorlow Impala | Impala SS 5 03-21-2005 02:32 PM
brake light won't turn off...Help! killatom Integra 2 09-02-2004 01:40 PM
