Old 01-07-2004, 03:39 PM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
camshaft install
never took my cam out do i have to take the 8mm nuts off the valves.
what bolts do i need to remove to take the cam out.
Old 01-07-2004, 05:35 PM
my91crxsi my91crxsi is offline
when u remove th cam the only bolts u should have to remove are the bolts on the bearing caps which i believe are 10 mm, then the cam should just lift out, DONT remove the nuts over the valves, u should really just get a manual and follow that tho
Old 01-07-2004, 05:56 PM
vesper's Avatar
Re: camshaft install
nah i see it. looked kinda like you had to remove them though. i got a sohc cam to replace the si cam. but for some reason it doesnt sit all the way in the berings. on the end of the si cam where the gear is theres a groove in the cam going inwards.
and a groove on the head comeing out wards.
the zc cam doesnt have this.
now do would by any chance if i brought the head to have this grooves shaved down would the cam work?
Old 01-07-2004, 07:34 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
the bolts you are refering to are the lifter adjuster bolts (to eliminate clicking valves, and determing proper valve lift.
the lifter component can be removed as a set by removing the cam seat.
Don't play with the adjusters on the lifters unless you plan on changing your cam with a different one OR want to retune the motor.
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Camshafts out of sync knightzwork ZX2 3 03-10-2009 06:30 PM
Camshaft installation tbifuzzy Chevelle 2 04-02-2006 12:16 PM
Help with B303 Camshaft install 1993_GT Mustang Talk 5 03-12-2005 08:53 PM
Mod Camshaft Install Instructions brentmcq Mustang Talk 2 09-06-2004 03:20 PM
Camshaft install!!! spy54 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 08-21-2002 11:02 PM
