Old 08-21-2002, 06:47 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
Camshaft install!!!
$400 for a camshaft and camgear install what is this all about anyone ever heard of it being this expensive?
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 08-21-2002, 06:56 PM
CRX586's Avatar
CRX586 CRX586 is offline
yeah, how hard is it to do this yourself? doesn't seem like you would have to take much of the engine apart...?
02 Lexus IS300
Old 08-21-2002, 08:51 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Sounds like a ripoff. All you have to do is take off the valve cover to expose all that stuff. It can't be that much once you do that.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-21-2002, 10:50 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
you said$400 for the cam, cam gear, and install? I'd jump on it. First of all, you have to set the timing to #1 TDC (top dead center). Then, mark and take off timing belt. Next take off valve cover. Next, unbolt and remove rocker arm assembly. You will have to remove the cam gear I believe before the cam can be removed. Then, remove the cam. So,then you lube up the new cam and lay into its bores. next, attach the cam gear and align it to the timing marks. Next re-attach he rocker assembly and perform a valve adjustment. Then reset the timing and make sure everything is done right. Finally, put on valve cover w/ new gasket. $400, sure man. I'd pay it.
Old 08-21-2002, 11:02 PM
spy54's Avatar
i hate this server it never works
it was 400 for just the installation i already have all the parts
AF Teen Crew
