Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-06-2004, 07:19 AM
ULTIMPORTPERF ULTIMPORTPERF is offline
Speedo And Tach Question
Maybe Someone Can Help Me I Have A Problem, I Have A 1990 240sx Sohc, And I Bought A Jdm 180sx Cluster (tach Goes Up To 9000). I Also Bought A Harness For A Digital Cluster From My Nissan Parts Dealership. I Hooked Up The New Harness, Plugged The Cluster In And Everything Works But The Tach. Now My Question Is This, If I Put The Sr20det Swap Into The Car And Change The Engine Harness, Will The Tach Work?
Thank You
Eric
Old 01-06-2004, 08:02 AM
vsiev vsiev is offline
Send a message via AIM to vsiev
The reason why the tach wont work is because the 180sx has an sr engine and you need an sr ecu. Right now you have a sohc ecu and engine. I done this before when I tried to put a cluster from a sohc to a dohc car...tach didn't work. Hope this help
Old 01-06-2004, 08:21 AM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: Speedo And Tach Question
The signal that the SOHC motor puts out can't be read by a DOHC tach. So yeah, when you get an SR20 then it will work.
speedo and tach needle lights out Pantdino ES300/ES330/Windom 6 12-02-2005 08:10 PM
99 G. caravan speedo and tach problem billnq0w Caravan | Voyager 2 02-12-2005 05:29 PM
how can a speedo and tach be calibrated? trahc 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 01-10-2004 04:34 PM
correct speedo and tach??? NOTAGAIN Off-Topic 11 11-18-2003 02:20 AM
speedo and tach not working walt0023 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 04-07-2003 07:01 PM
