Old 04-07-2003, 12:32 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
speedo and tach not working
i can't figure this one out for anything. my speedo and tach stopped working one day and i don't know why. i'm not even getting any kind of a signal from the tach so i know its not the gauge cluster. any suggestions??
Old 04-07-2003, 12:37 PM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
might want to check the speed sensor
Old 04-07-2003, 12:42 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh ur speed cable might be loose. ITs from the firewall to ur tranny. u'LL see it.
Old 04-07-2003, 02:59 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Sounds like a gauge cluster problem seeing how they both went out. The speedo and the tach are no way connected besides in the cluster. The tach comes off the distributor and teh speedo comes off the tranny. I would double check your cluster because it sounds like thats the problem.
Old 04-07-2003, 03:03 PM
nah, the tach stopped working before the speedo
Old 04-07-2003, 03:06 PM
Than since your not getting a signal from the tach i would look to the distributor. For the speedo, make sure that the cable is all the way pushed into the tranny and that the clip is holding it in.
Old 04-07-2003, 07:01 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
check the fuse for your turn lights. i blew that one by mistake, and drove around for a while thinking i blew my cluster out. but the speedo is mechanical, so even with that fuse burnt out you should still get the speedo, check cable by taking it outta the tranny and spin it while someone watches your cluster. if it moves the numbers or the needle, your speedo is fine, just make sure the cable is seated into the tranny all the way. also, are the other gauges working? like gas and temp? if they arent, its that fuse.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
