Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 01-06-2004, 12:48 AM
ArtCan ArtCan is offline
Unhappy Ignition/starter problems?
Hi there. I have a 1998 Dodge Stratus that was working fine up till today. I started the car a few times today due to the cold weather and on the last time, the car wouldn't start. Just click, click, click. What is weird is that the lights, oil light and electronic odometer never went out with the keys out. I towed it to a shop where they boosted the car. Car started except the starter does not disengage. Also, when you turn the key, the car starts at the accesory stage. I have replaced the battery and also have noticed a fuse under the hood that was blown( can't remember which one, but it was a 20). When I replace that fuse, the car starts automatically without a key. I was told by a friend that it could it be the ignition switch that may be stuck? Any ideas?
Old 01-10-2004, 01:57 AM
macncheese macncheese is offline
could be a stuck switch, but i also burned a wire to the starter and it arced on the block, causing the same constant-on. check your wires out, especially the brown wire (relay and starter) and the thick red wire.
tony
95 Camaro Problems CamaroV6 Camaro Discussions 8 03-10-2010 12:55 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
Concorde ignition/starter problem!!! Mjlarson Concorde 6 09-01-2008 02:04 PM
1992 cherokee ignition/starter problem? swamppirate Cherokee 4 12-02-2004 07:10 PM
ignition starter problem!><! help please dube1113 Cherokee 1 09-29-2004 01:39 PM
