Old 12-01-2004, 06:56 PM
swamppirate swamppirate is offline
1992 cherokee ignition/starter problem?
When I turn the ignition, the dashboard lights come on but the jeep does not click or turn over. After 15-20 attempts at trying to turn the ignition it finally engages and the engine starts. Any thoughts???
Old 12-01-2004, 07:17 PM
Carlson327 Carlson327 is offline
Re: 1992 cherokee ignition/starter problem?
I had a similar problem on my '92. It turned out to the neutral safety switch. Sometimes it would start, and then sometimes it would do what you are saying. I finally got tired of the situation and had it replaced.
Old 12-02-2004, 11:30 AM
Thanks for the info... I took it in this AM and the shop confirmed the neutral safety switch. Not cheap but its got to be done!! Thanks again...
Old 12-02-2004, 05:30 PM
markhamsr markhamsr is offline
an old trick I use frequently on mine is jiggle the shifter or put it in neutral. always seems to work for me
Old 12-02-2004, 07:10 PM
mumblemouth mumblemouth is offline
or take a look at this site. details on how to fix it your self at little cost
i also have a prob with the nss and havent gotten around to cleaning it. for me starting my jeep in neutral after it wont crank is a temp solution.
http://jeepin.com/features/nss/index.asp
