Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-03-2004, 09:33 PM
Steiner's Avatar
Steiner Steiner is offline
squeaking after Eibach install
Since I've installed my Eibachs springs and new endlinks I've noticed a squeaking noise coming from the right rear wheel. The noise is consistent with the speed of the car, but it stops when I apply the brake.
BTW...In order to swap out the rear springs I had to remove the calipers. Could putting them back on too tight or too loose cause this squeaking to happen?
Old 01-03-2004, 09:44 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
IMO it could be from the caliper....but i wonder if maybe its comming from a inproperly seated spring....
for the caliper it should be easy...take the wheel off and resintall the caliper making sure you install it properly....you might also want to consider taking off the pads and putting some silicon on the back to prevent them from rattling
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 01-03-2004, 09:46 PM
R1-rider's Avatar
R1-rider R1-rider is offline
Send a message via ICQ to R1-rider Send a message via AIM to R1-rider
Need a little more information than that:
Is the noise only at certain speeds? and is it consistent as it squeaks all the time, or only when it hits bumps? Are you absolutely positive it is from the new springs?
When you brake it relieves most of the pressure on the springs, so it probably is something involving the springs or struts.
When you put the caliper back on did you tighten one bolt all the way down, then the other? or did you make one snug then the other snug before tightening all the way?
Put your car in park with everything off, then just simply rock the car up and down by pushing on it, and see if you can hear the noise still.
Otherwise it might be a hub bearing, or even something rubbing somewhere.
......or if your a loser who drives a Civic with a type R sticker, racing stripes, blasting really bad rap music through your suburban area with your pretentious "I’m 21 but I’m still in high school girlfriend" while driving with your hand up on the top of the steering wheel exposing your underdeveloped pasty white vitamin deficient arm and wearing your backwards BS upside down visor hat while feeling the tacky as a "Florida vacation" single diamond earring in your ear, If you are this person...with any luck the sun in its precise celestial positioning as you putter on by...will reflect its scorching rays into your earring, bouncing intensely in your rearview, and finally making contact with your eyes through the thin cheap lense of $5 gas station Oakley rip off glasses.. then burning your retnal cones into smoldering melting gobs of ocular material as you are blinded by the purest form of energy in our known universe, and as you scream no one can help or hear you because they don’t know what’s going on since the weed whacker sound of your shitty tiny little muffler which makes the Civic sound like a 747 rages on underneath making everyone turn at disgust and comment to thier husbands or wives how much of a dickweed you are by attaching that automotive abnormality to your stock economical daily driver engineered by Japanese Automotive specialists to fit the needs for entry level business workers in their early 30's, however your pathetic looking $11,000 car which you want to look like a friggin spaceship with redundant ground effects is now out of control since you are blinded, and as your car plunges off the side of a cliff while you scream in the purest form of terror while knowing you have lived a horrid excuse for a life, by doing the bare minimum in every facet of existence, while getting fired from one pathetic job to another, the majority of your time spent slacking smoking dope, getting kicked out of school, polishing your "game" on sweet innocent underage girls you eventually 'de flower' through exhaustive yet succesful attempts to get the date rapist drugs you have stashed in the glove compartment, into your poor victims drinks while offering them to take the "Pepsi Challenge" while making your mother hate you, and your poor father who wishes he had a daughter instead of your pathetic ass, since a girl would be more of a man than you ever were, like the occasion when you were hit in the arm by a wild pitch in little league, then you cried like a fat kid who dropped his ice cream cone, I'm already envisioning you impacting the rocks below, in a spectacular fireball ignited from the residue hairspray from your girlfriend plastered in the fabric passenger seat, blinded by your earring, deafened by the loud "Bling Blingin", and I will smile and roll around on the ground in orgasmic delight while you are consumed by flames whose intense heat and fury will liquefy your bone marrow that I will use to make jelly beans out of and eat them happily at your funeral as midgets dressed like Alex 6005321 from "A Clockwork Orange" dance around your coffin to loud industrial style techno music and strobe lights, and I will sleep soundly at night knowing another successful conquest of Darwinism has been attained.
Old 01-03-2004, 10:13 PM
Steiner's Avatar
Re: squeaking after Eibach install
The noise is a repetitive squeak. It was definately not there prior to the spring install. The faster I go the more it squeaks...the slower I go the bigger the time interval between squeaks. When I hit the brakes the noise goes away. There seems to be no relation between bumps and this noise as far as I can tell. It's consistent with speed.
"When you put the caliper back on did you tighten one bolt all the way down, then the other? or did you make one snug then the other snug before tightening all the way?"
Unfortunately I cannot answer this. As I was doing the work on the left rear side my buddy was doing the work on the right rear...the problem side. On the left side I got each bolt finger tight, then finished the work with the ratchet. I'm the novice and he's the amateur enthusiast though for whatever that's worth.
I'll go out to the car right now and push it around. So emergency brake should be off I guess for this test? I'm parked on a flat surface so it's cool either way.
Old 01-03-2004, 10:29 PM
Steiner's Avatar
I couldn't re-create the squeaking noise, but I did hear a popping sound coming from the left rear strut tower when I bounced the car up and down. Wonder what the hell that is?
Old 01-04-2004, 04:11 AM
Neutrino's Avatar
Yaya Master
Re: Re: squeaking after Eibach install
could be that the strut or spring are not fixed properly....that could cause a bit of play and a popping sound
(\__/)
Old 01-04-2004, 08:15 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
what bushings dis you use (if any).
synthetic bushings are stiffer, but they tend to squeak.
Mustangs are nice, but I'd rather have one of these...
Old 01-04-2004, 07:55 PM
Steiner's Avatar
The squeak has been fixed...
Instead of putting the car up on the ramps or playing with the strut tower I decided to take a quick look at the caliper this morning before doing anything else. I grabbed the jack and tire iron out of the trunk and then...WTF! There were 2 lugnuts missing on the wheel. Totally gone! Two others were loose. I took my fiance's truck to Kragen and bought a lugnet set for $5. I took a quick drive and the squeak is gone. I'll order another OEM set from my Dodge dealer tomorrow.
This is the last time I let somebody, other than a professional, work on my car. I'm lucky that wheel didn't fall off on the freeway Friday night. I'm so pissed right now. I've decided to cut my losses and let the alignment shop fix that popping sound on the left side when I bring the car in on Tuesday.
Live and learn.
BTW...I used Energy Suspension brand urethane bushings. I haven't put the new set on the front sway bar yet but I'm planning on doing it next weekend.
rubber squeak after quickstrut install northern piper Windstar 0 06-07-2008 08:24 AM
Before/After Eibach 1" drop (pics) Lead Foot LS | MKZ 5 11-11-2005 11:49 AM
Tokico+Eibach+Installation=PICS quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 16 08-24-2004 11:52 PM
WOT vibration after eibach install??????? bemis Grand Prix 0 03-16-2004 03:55 PM
Engine Squeak after turning off ignition solar_Sc0-rcher Maintenance 2 02-25-2002 06:25 AM
