Old 12-29-2003, 12:27 AM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
getting new turbo
ok so im getting a new turbo on my car, and just seening what you guys think
GT-14
GT-10
20g
just tell me what you guys think
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 12-29-2003, 12:47 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: getting new turbo
i like the gt14 the 56 trim is good , has good top end and good spool up,
next i would go 20 g nice topend also
the gt10 is to small in my opinion like a 16g.. good for qucik street racing but not to much top end.. the small 46trim will and only 44\lb air flow wont give you lots of power..
i like the gt-14..
let me know how it works out for you..
1
Shift_BOOST
97 s14
Old 12-29-2003, 01:15 AM
this is what a couple guys said about the GT-14
"IMO the GT-14 is overkill for a street car, especially without a fully built motor. With a flow rate of 65 lb/min (940 cfm), you are going to be well below the best usable efficiency of the compressor unless you run high boost all the time. You will also most likely experience alot of low end surge with a compressor that large on a 2.0L engine, causing a loss of some driveability."
Car pics
Old 12-29-2003, 01:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
Well, I might as well toss my 2 cents in the barrel since I have some experience with the turbo. The GT14 compressor wheel, or GT30/40 hybrid, is in my turbo. It is big. 98% of DSMers are not prepared to run a turbo that large. I get full boost at ~4400 rpm with a GM airflow sensor. I never see any surge. It lags too much to surge in my case. In the full BB version, it may be a little better, but dont expect much. GT10 is small, and I'm notsure why its even in the same conversation as the GT14 A "large" street turbo would be something around the 20g. I like SBRs TDO6H version, that what I used to run the times in my sig. The GT12 is a great alternative if you want a BB turbo. The GT13 has run 10s, just ot put things in perspective.
Bear in mind that running a BB turbo brings a lot of maintance responsibility. The oil has to be super clean, and the pressure has to be just right. Thatusually means taking the feed from the head, with an inline filter. For an everyday street driver, I still think the TDO6H 20g is the best thing going. It will easily support 11s on a well modded, well tuned car, and I ran 25 psi everyday on pump gas (93) with full boost at ~37-3800 rpm. It can be boughtnew for a grand or less, if you go external (and you should on anything over a 16g, in my epxerience).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-29-2003, 01:28 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
I always had a thing for the GT12
http://www.slowboyracing.com/GT%20tu...2_content.html
-Agim
Old 12-29-2003, 01:34 AM
turbo2nr's Avatar
would you guys recomend a bb turbo for a street application?
and how good is the gt-12?
it seems good when does it make boost? and will the 7cm housing help the spool up time.
1
Shift_BOOST
97 s14
Old 12-29-2003, 01:42 AM
AF - Advisor
GT12 is a great turbo. Will easily do 11s well supported and well tuned. I would expect 25 psi by 4k rpm. I already talked about the BB thing. Wether or not its a "street" turbo for YOU is up to you, not us. IF you are willing to take the necessary steps to make it work, go for it. If you arent, stick with conventional bearing turbos.
Kevin Jewer
Old 12-29-2003, 01:53 AM
turbo2nr's Avatar
cool seems good enough
thanks again for sharing you knowledge
lolz
1
Shift_BOOST
97 s14
2007 models to get new 6 speed auto (08 may get new V-6) Jaguar D-Type G6 2 08-01-2006 11:16 AM
Getting new engine and turbo. 2.2 or 2.4? Lances133 Cavalier 0 03-25-2006 07:22 PM
getting new turbo and coil overs advice pls bob stone MR2/MR-S 1 10-10-2005 01:31 PM
Im getting a turbo, any other mods I should get? JBT3 Tiburon | Tuscani 4 04-24-2005 11:21 AM
88 rx7 anniversary, new turbo manifold, or new turbo kit? ghostrx7 RX-7 6 04-09-2005 08:19 PM
