Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-21-2003, 06:39 AM
Jack0715 Jack0715 is offline
Question '01 4Runner rear axel seal repair
I'm new here. Took my '01 4Runner in for an oil change and dealer told me my rear axel seal needs to be repaired to the tune of $200. The truck has 43 thousand miles on it. Is this a reasonable cost or should I take it to the local mechanic who might fix it for cheaper? There are no leaks and it doesn't ride funny. How long can I go 'till I get it fixed? I get paid next week. Thanks.
Old 03-14-2004, 08:28 PM
ericwhin ericwhin is offline
axle seal leaking
My 2000 4runner and a coworker's 2000 4runner had the same problem which Toyota fixed for free. Both of us had symptoms where the transmission would start clunking very loudly as vehicle was put into gear especially on hills. The oil soaked the rear brakes causing many parts to be replaced. This was considered a silent "campaign" by Toyota. If you complain loud enough they should repair your vehicle free or at least a reduced rate since your mileage is so high.
Old 03-14-2004, 11:47 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: '01 4Runner rear axel seal repair
"There are no leaks"
How did they judge the seal was bad if there are no leaks? Is there any gear oil at all in the drum or behind the brake shoes on the backing plate? They may be pulling your leg.
Old 03-15-2004, 02:01 AM
ToyotaTech ToyotaTech is offline
Campaign? I have worked for Toyota and have not heard of "any" silent thing? buy the way if u have the time and mileage on your vehicle then u should be still under warranty on this seal powertrain warranty is 5years or 60,000 miles.
Old 03-15-2004, 01:59 PM
seal leakage
Yeah, that's why it's a "silent campaign". No one at Toyota will fess up to other owners having the same problem and if I didn't happen to have a coworker with the exact same clunking symptoms (and hers is a 2wd) I would not have known.
Anyhow I pulled the service order from Jan 2001...........They replaced the rear shoes and ground the brake drums. They found the LR axle seal leaky causing brake to stick on. axle seal deformed due to material defects 90310-50001.......this is all on the report.
So yeah, the oil did leak down the axle. Hope this helps.
'93 4.6L Rear Main Seal Repair Costs ysmlee Grand Marquis 1 09-11-2008 01:45 PM
[URGENT] - '01 Civic lost and Axel Seal and now... Doubletap '01-'05 Civic 0 11-05-2007 09:14 AM
rear main seal repair on 98 voyager? cary leonard Caravan | Voyager 1 11-28-2006 08:47 PM
rear axel seals jim72 Tundra 0 01-23-2006 06:58 PM
98 4runner rear axle seal stude Dealer Experiences 2 05-23-2005 07:07 PM
