Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 12-20-2003, 05:57 PM
saralee saralee is offline
Unhappy 1990 Galant No Power
I have just acquired a 1990 5 speed Galant. The car runs fine when it is cold. After it heats up, it generates no power and dogs really bad when you attempt to accelerate or take off from a stop. If I turn the car off and back restart it, I can drive if for a short distance, and then have to repeat the procedure. Incidently, the car idles fine, the problem only occurs when you step on the accelerator. Any ideas?
Old 12-24-2003, 10:41 AM
bobinito bobinito is offline
same hea
oh man dude i have the same damn problem with my 91 pissin me off too but when i find out whats wrong wit mine ima tell u iight
Old 12-24-2003, 09:02 PM
morrisosu morrisosu is offline
No Power?
What type of ignition system does the car have? It sounds like a coil or ignition control module is getting hot and puttering out. Just a guess, could be many other things.
Old 12-27-2003, 05:06 AM
harrysolve harrysolve is offline
Send a message via MSN to harrysolve
Re: 1990 Galant No Power
Hi there,
What is your engine code for your Galant? Is it the 4g63T Cyclone?
Regards,
HarrySolve
Old 12-27-2003, 01:25 PM
After further trouble shooting, I found that it had nothing to do with temperature, just driving. Then, I noticed when the car was idling, but wouldn't move, that I could hear an oscilating hum coming from the rear. I thought, fuel pump! I found that I could reproduce the problem by shutting off the car, starting it, and then jumping up and down on the back end of the car. It would begin the oscilating hum in the back again. So now, I'm thinking I have crud in the fuel tank that is blocking the pick-up on the fuel pump, or the fuel pump is bad. I have just ripped the fuel tank off of my car and am getting ready to check it out. I'll let you know what I find. Let me know what you guys think in the mean time.
Thanks
1990 Mercury Sable power window problems joannslaw Sable 1 05-16-2010 04:25 PM
1990 Galant GSX/ 1991 Galant VR4 project Sleepr awd Members Project Cars 31 01-04-2008 05:45 PM
1990 Galant power windows... down, but not up.. Roto_Boy7 Galant 2 11-15-2005 04:28 PM
1990 Galant Lordzemus Galant 6 01-17-2005 03:13 PM
1990 Galant GSX RoXy29 Galant 0 03-04-2004 12:08 AM
