Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-19-2003, 11:42 PM
tdf27 tdf27 is offline
'96 Headlight weirdness
Hi All,
In the last 4 months, I've had two occasions where the headlights on my 96 Aurora refused to come on. Both times it was at dusk & the first time, after starting & stopping the car a couple of times, everything was fine. I chalked it up to the full moon (which explains a lot of my wife's behavior). Second time, no joy, even after trying everything I could think of, including disconnecting & reconnecting the battery. The next day, lights worked & have since.
Any experience - suggestions with this?
Old 12-20-2003, 01:01 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: '96 Headlight weirdness
Will they come on using the multi-function switch? Is this problem only with the twilight sentinel(automatic on/off)?
Quality isn't expensive, it's priceless.
Old 12-20-2003, 02:32 PM
Re: Re: '96 Headlight weirdness
Nope. Wouldn't work with the switch either no matter how many times I cycled the lights on & off. All that did function was the high-beam flash which acted as expected when lights are turned off.
Old 12-20-2003, 03:45 PM
Indy8's Avatar
Re: Re: Re: '96 Headlight weirdness
So now they won't come on at all?
Old 12-20-2003, 04:10 PM
Re: Re: Re: Re: '96 Headlight weirdness
Lights are fine now but if it happend 2x in the last 4 months, I figure its gonna happen again, exactly when its the least convenient... The fact that it went away by itself makes me think a senser or circuit. Is there a way to reset these things?
Old 12-20-2003, 04:29 PM
Indy8's Avatar
Re: Re: Re: Re: Re: '96 Headlight weirdness
Some owners have experienced problems when using auto mode for extended periods of time. Excercising the main switch seemed to help clean the contacts and restore normal operation. With electrical, intermittent problems can be a bad ground. If it happens again, replacement of the whole switch is about $350 at the dealer.
Old 12-20-2003, 04:43 PM
Re: Re: Re: Re: Re: Re: '96 Headlight weirdness
Sounds like my situation - used auto mode exclusively for the past 2 years. I'll try with the switch for awhile & see what happens.
Thanks for the advice!
headlights davidrobert2 Intrepid 1 11-20-2009 03:02 PM
'96 Window Lift Motor - Driver Rear Intuit Park Avenue 0 08-03-2009 03:24 AM
Change 2006 Allure Headlight kale39 LaCrosse/Allure 1 04-28-2009 07:05 AM
93 Aerostar, no Headlights billa63 Aerostar 2 03-08-2009 07:10 PM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 09:49 AM
