Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 03-04-2009, 03:20 PM
billa63 billa63 is offline
Exclamation 93 Aerostar, no Headlights
my headlights won't work this morning, everything else seems to... even the running lights
I pulled every 25 and 30 amp fuse and found 1 bad, but lights still have no power, are there 2nd fuses/links under hood and if so where?
Old 03-04-2009, 07:12 PM
rhandwor rhandwor is offline
Re: 93 Aerostar, no Headlights
Look at the starter for a burned fuse able link. You can use a DVOM and make sure the headlight switch and ignition switch are good.
Old 03-08-2009, 06:10 PM
Cool Re: 93 Aerostar, no Headlights
Just a follow-up, Fusible links were good.
Checked power and other points and found that sockets had power but one was singed at ground wire. Secured better grounding and lights now work!
Tags
areostar , ford , fuse , headlight
