Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 12-17-2003, 12:24 AM
seiya9413's Avatar
seiya9413 seiya9413 is offline
Send a message via AIM to seiya9413
Question what's double clutching?
hi all this is a very stupid question but yes what is double clutching? does it damage your car in anyways? does double clutching have to do with racing your car? is it the PROPER way to drive a manual car, because i been driving and people's been asking me "do you know how to double clutch"? please need some answers thank you all
VROOM VROOM VROOM!!!!!
Old 12-17-2003, 01:00 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: what's double clutching?
Ok, I want you to go around to every single person who told you that and give them a swift kick in the nuts for me. Then you can do with them as you like.
Double clutching is used on either cars with no synchros, cars with bad synchros, or cars where the owner wants to save the synchros. It's also used for DOWNSHIFTING which no one seems to understand. I swear that shitty movie is corrupting every single person who watches it. Double clutching cannot be used for upshifting like in a drag, what you do is push in the clutch, shift to N, let out the clutch, rev-match for your next gear, push in the clutch, shift into the gear, release the clutch. It's like normal rev-matching with one extra step. In normal rev-matching you speed up the engine to get ready for the downshift, but the transmission is still spinning the same speed as it was. Then the synchros have to work overtime to line up the gears so they mesh together properly and don't grind. When you double-clutch you speed up the engine and the transmission to the new speed, so when you shift into gear the synchros barely have to do anything to line up the gears.
Actually if you do it right you don't even need to use the clutch to go into gear, but I wouldn't try that until you've been driving a manual for several years and have perfected it.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-18-2003, 12:26 AM
seiya9413's Avatar
thank you lots that really cleared up alot of things then what did they mean by granny shifting? and you what you mean by shifting without a clutch is that possible???
Old 12-18-2003, 02:15 AM
sr20de4evr's Avatar
It doesn't matter what he meant by granny shifting, it was a movie and ATLEAST 90% of everything said in that movie is completely and utterly wrong. Please forget about anything even mentioned in that movie because it will just confuse you about how things really work.
And yes you can shift without a clutch, you just have to get the timing perfect. If you don't do it right you will grind, hurting your tranny and murdering your synchros. That's why I said you shouldn't even try it unless you've been driving for many years and have everything perfect.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-19-2003, 06:12 PM
mreff mreff is offline
Talking Re: what's double clutching?
sr20de4evr, I am suprised and impressed. Good job at not being dumb!
Old 12-22-2003, 12:25 PM
Mancini Mancini is offline
Old 03-13-2004, 12:24 AM
team_mechanic team_mechanic is offline
in the move they just throw out some catchy phases like double cluth and granny shifting
also shifting without the clutch is often refered to as floating gears
Old 03-14-2004, 02:42 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
yeah, I would never shift clutchlessly while racing. It would grind big time. But it's pretty easy to do when driving normally. Just press the stick gently towards the gear you want to get into and when the rpms drop into the right area after an upshift, the stick will slide right into gear.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Trip-clutch and double clutch...what are they? HellGoneWild Engineering/ Technical 9 04-15-2003 11:49 AM
Double clutching Edho2002 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 02-22-2002 02:22 PM
double clutching Charlie Hu$tle Street Racing 16 01-22-2002 02:31 PM
double clutching question?? vtecattack Street Racing 15 01-10-2002 04:16 PM
