Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-09-2002, 04:14 PM
vtecattack vtecattack is offline
Send a message via AIM to vtecattack
double clutching question??
I always hear people talking about double clutching!! What exactly is double clutching and whats the best way to do it?? Thanks.
Old 01-09-2002, 04:24 PM
JasonAccord98LX's Avatar
JasonAccord98LX JasonAccord98LX is offline
Send a message via AIM to JasonAccord98LX
im sure that you will get a much more technical response from fritz or someone like that, but in simple terms double clutching is pushing the clutch in two times instead of once in between shifts. ex. you start off in first gear,get to where you want to shift, push in the clutch shift to 'N', release the clutch, push the clutch in again, and shift to 2nd. Double clutching is used mainly to help line up the synchronizers inside your gearbox better, which makes for a smoother shift. This method is needed mostly on older trucks and large vehicles.
A pretty simple and basic explaination.....if you wait im sure that the more techical ones will come.
btw, my friend drives firetrucks for the fire department and they hae a really old truck which needs to be quadruple-clutched (push the clutch in 4 times in between shifts) to properly line up the synchros for a good shift.
-Original PH Member-
Registered in May of 2001
'98 Honda Accord Sedan 2.3L VTEC 4cyl 5-speed
Generic Cold Air Intake
205/60/15 Bridgestone Potenza RE950's
Save the Oompa-Loompas.....a site I helped create
http://www.oompa-loompas.net
Old 01-09-2002, 05:05 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Double clutching is not really needed on recent cars. The only reason for double clutching in my opinion is when you are downshifting, and even then it's more rev-matching than double clutching.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 01-09-2002, 05:12 PM
thanks for the info. I didnt think that it sounded beneficial as far as when you are racing...seems like more time and trouble than just clutching once. So there really is no benefit from it as far as quicker 1/4 mile times??
Old 01-09-2002, 05:21 PM
for most normal applications and in your case, yes
Old 01-09-2002, 10:30 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
its more of a technique for rally racing, tractor mud pulls, or hauling big loads than 1/4 mile racing. however in my awd car i do a version of it on launch to keep my rpms up and get a better takeoff, im holding the clutch, drop it on green, then instantly push it back in again and drop it again. i have shaved over 1.5 seconds off my time by refining this method at the local track but i have no idea why anyone would do this through EVERY gear, like they imply on the fast and ferocious. unless of course u were competing in a tractor pull or hauling a big load.
Old 01-10-2002, 12:48 AM
thats fast and furious for you!!
Old 01-10-2002, 01:58 AM
jeisai jeisai is offline
Send a message via AIM to jeisai
Was the eclipse in F&F a GSX? If it was, it would have been all wheel drive, and they could've been talking about doing the same thing delaysion does with his scooby.
Old 01-10-2002, 10:59 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
he said, "granny shifting, not double clutching like ya should"
and if you know english and the definition of all terms used, you'll be able to realise that the term "double clutching" is used incorrectly in that statement, no matter how much you try and twist it around.
Old 01-10-2002, 02:46 PM
jOYRiDe jOYRiDe is offline
i thought only trucks double clutch do it when they go downhill
Old 01-10-2002, 02:52 PM
drift's Avatar
that is true, but some race cars still doubleclutch when slowing down for a corner because one: it's a smoother shift without disrupting the drive wheels. dropping the clutch on a downshift can cause the drive wheels to break traction from the tranny trying to speed up to the motor.
two, some race cars still have a dog box... no synchros.
street cars dont have dog boxes, so double clutching a street car is pretty useless, unless you're racing and want to make a proper downshift and transition into a turn
Old 01-10-2002, 02:59 PM
hey thanks for that info...
now i understand the concept of doubleclutching....
u americans will probably use dogboxes soon in the 'race' wrx...subaru have pretty weak trannys...
Old 01-10-2002, 03:06 PM
um.. that doesnt make any sense at all. i believe that if your trannys were weak, you would run synchros so when you shifted there would be less wear and tear on the gears and bearings. and i dont believe that subarus have weak trannys.
Old 01-10-2002, 03:17 PM
i do
ive seen them go pop... and its very common from where im from (swapping trannys)
Old 01-10-2002, 03:25 PM
drift's Avatar
you should stay abreast in the WRC... scooby trannies go pop a lot.
but the new 2002 WRX should have taken care of that problem... they beefed up the tranny.
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
Stupid double clutching question... chadm_88 Driving Style and Technique 2 08-30-2005 09:02 PM
Trip-clutch and double clutch...what are they? HellGoneWild Engineering/ Technical 9 04-15-2003 11:49 AM
Double clutching Edho2002 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 02-22-2002 02:22 PM
double clutching Charlie Hu$tle Street Racing 16 01-22-2002 02:31 PM
