Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-16-2003, 07:14 PM
Carson777 Carson777 is offline
heads
hi... I would appreciate anyone letting me know if the newer headlights like on the 2003 will fit the 2000-02 models... I have a 2001 LS Sport
The new headlights have clearer corners, which I like. I have till tomorrow to decide... please let me know specifically!
Thanks
Old 12-16-2003, 08:12 PM
MercCougarXR7's Avatar
MercCougarXR7 MercCougarXR7 is offline
Re: heads
Want clear corners? Do what I did, because the new lamps are very expensive, and have to be modified to fit into the pre 03 bodies.
I removed my headlamps, and put them in my mommy's oven at about 200F, for about 10 minutes.
The clips on the bottom are popped off, and I seperated the plastic lense from the grey body with 2 flat screwdrivers.
The orange piece of plastic just pops out of the grey frame, and that's all there is to making a clear corner on the LS.
I used a bead of silicone when I resealed the lights, because they leaked anyways before they were seperated.
An amber bulb was used, and the effect is awesome at night - a projected orange beam of light.
Side view,
Front view with lights on:
Front with lights off:
Let me know if and how you make out, OK?
Enjoy,
Kevin.
2000 LS8 Sport, 1992 XR7 5.0 HO
Old 12-16-2003, 09:42 PM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: heads
If your current headlights have gray sealant, the above method will work. If they have black sealant, don't bother. The black is silicone and won't melt until about 600*F...well after the polycarbonate lens is a puddle.
1994-302 aftermarket cylinder heads? spoovey F Series 0 05-21-2010 10:47 AM
non PI head swap to Pi heads BigCheech Mustang Talk 7 03-11-2005 05:06 PM
replacing a head gasket and checking head rocprod '88 - '91 Civic | CRX | Wagon | Shuttlee 3 11-09-2003 06:52 PM
Cylinder head torque specs/ cam line up before putting head on black 95 Off-Topic 1 10-13-2003 10:06 PM
D15A2 needs head, will D15B head fit? mpanther '71-'87 Civic | CRX 1 09-18-2003 11:11 PM
