Old 11-09-2003, 06:15 PM
rocprod rocprod is offline
replacing a head gasket and checking head
Have 90 honda crx and have come to the conclusion that the head gasket needs to be replaced car smokes and runs hot, could someone advise how to replace head gasket and i was told something about checking the head which part would that be, would some one have pics of which part the head is and could someone walk me thru replacing the head gasket also is there any special tools neede like torque wrench and one other thing that i was advise is to change the timing belt if so would that be difficult,
Old 11-09-2003, 06:33 PM
BullShifter's Avatar
Re: replacing a head gasket and checking head
http://www.binghamtonlife.com/manual/2gsm/default.htm - factory repair manual
yes you will need a torque wrench & true bar - or have the head inspected. you might as well change the t/belt, water pump, drive belts, thermostat, coolant, valve adjustment, plugs, etc. while its all apart.
Old 11-09-2003, 06:37 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
If your head gasket is bad there is a reason usually caused by the head worping. So dont just expect to change the gasket and be ok, have the head checked so you dont have to do it again in a week. Espeically since it has been over-heating.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 11-09-2003, 06:52 PM
Re: Re: replacing a head gasket and checking head
thank you is there a specific pic of the head within the link that you provided i have an idea what it acutally consist of but want to make sure i have decided to get this done myself for the experience but want to get it done right what does the head consist of
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
Replaced Head Gaskets and now have Problems sbriar Lumina 5 06-12-2009 10:30 PM
Replaced Head Gaskets and now have Problems sbriar Lumina 0 05-28-2009 10:25 PM
Help with head gasket and oil pump replacement. b16Civic Yukon 0 02-07-2008 10:57 PM
Replace the head gasket or the head? lilaroe Escort 3 01-11-2006 06:16 PM
