Old 12-16-2003, 05:13 PM
czech09 czech09 is offline
Send a message via AIM to czech09
3000gt speed/hp question
ok hi - i'm looking to buy a 3000gt from this guy very soon - the offer is nice and I love the car - first thing that struck me as being wrong was the fact that he says the timing slipped by one tooth and bent 1-2 valves on the rear head - he says it will cost $300-500 for the repair if I get it taken to a shop - what do you guys think is that about right? Second thing is he said the car ran a 12.5 b4 easily with a bad driver, passenger, spare, jack, and street tires and @ low boost 14 @ max. I believe that but that was b4 most of his mods which are listed below - he says it can run mid 11s now easily on street tires. He says that the car has 550hp+ but never had it dynoed - he doesn't have any recent times either - and said that a 3000gt vr4 running mid 11 quarter miles will have @ least that much horsepower, so let me know if you guys think that's what it would run and approximately how much boost ?
Here is the list of mods :
It has dr650 turbo's, 550cc injectors, HKS fuel pump, ARC 2, EVC4, new carbon clutch, NEW factory short block, NEW Kormex transmission
BRAND NEW factory short block. (proven to handle over 700 HP
on the stock bottom end)
Brand NEW getrag transmissionw/25spline output shaft conversion with a warrenty
Brand new driveshaft
rebuilt ECU just rebuilt last week
New Master & Slave Cylinders
New Throttle Servo Kit
New O2 Sensors
New Fuel Filter
new cv axels
new rotors, new matrix metal brake pads, new brake lines.
new AC compressor, and changed over to R132
HKS 550 fuel pump
HKS evc4 EBC
K&N 82mm Intake
DR650 turbo's
flow tested 550cc injectors
carbon cLutch
3" down pipe
no pre or main catalytic converters
ARC II fuel controller w/ ARM I- (which eliminates the stock MAS, and lets you control the AF ratio, it's the best on the market. Better than the SAFC.)
DN chrome y-pipe
blue oversized wires, new plugs just put in a week ago
Apexi twin chamber BOV, REALLY LOUD!
Autometer A/F gauge
Autometer boost gauge
dual gauge pod
ARM 1 AF gauge
Window tint.
It has 1 AF gauge for each O2 sensor so It can be properly tuned.
I can easily show anyone how to tune this beast. It can easily hold 20+ psi
770 injectors would be included also
Let me know how fast this car could run a quarter mile and how much hp it's got (to the wheels) thanks - I really appreciate it - and one last thing what do you think would be a good price for it let me know thanks
Old 12-16-2003, 06:31 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
yeah i've got the apexi twinchamber bov also it is very loud, but yeah it sounds reasonable to run 11's, let yogs check out the mods he can tell you a thing or 2. but to me it sound like the beast he is teling you it is,
how much you buying it for?
Old 12-16-2003, 07:03 PM
Re: 3000gt speed/hp question
i'm not buyin it yet - where's the yogs guy? u got aim or anything?
Old 12-18-2003, 01:19 AM
youngvr4's Avatar
STREET RACING GURU
he was on here, if he doesnt know he can tell you were to go to get the answers. he probably skipped it cause it was so far down.
hey yogs, give us some help here.
Old 12-18-2003, 10:50 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Hey guys
First let me tell you my gut reaction. Something sounds fishy. Lets start with the claim of 12.4 on only 14 pounds of boost. Thats virtually impossible with a great driver and a perfect launch.
I'd make some calls, 500 seems low for that repair job. Not only that, but the timing belt (and associated tensioner etc) will need to be done if not already and that runs several hundred already. Just the fact the timing got out of wack is a concern. Should not have happened, but if he drove it like that for any length of time, there is going to be more problems in the engine.
550hp should put the car in the 11s. I do believe that. That list of mods might be able to get the car enough boost and fuel to make it.
Now on to the next baffling part. That list of mods says he has a "NEW Kormex transmission" and a "Brand NEW getrag transmissionw/25spline output shaft conversion with a warrenty" so which one is it? Can't have both unless he means he got the transmission from Kormax. I thought they only sold rebuilt engines so color me suspicious.
I tell you, have this car looked over by a mechanic you trust. Things just don't sound on the up and up to me based on what I read here.
As for a price. I don't know what year the car is. The fact it needs some work as well as all those mods, I wouldn't pay more then 3-6K for a first generation (and then up from there depending on the year). Remember, the cost of the mods do not increase the value of the car to most people. Anyone who claims they do is just trying to justify their price tag.
As for the quarter. Its all in how well a car is tuned with those mods (and a working engine). I could see 500hp+ and high 11s.
Resistance Is Futile (If < 1ohm)
Old 12-18-2003, 06:19 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
kormex does rebuilt our transmisions, and puts in better syncros and a hardend output shaft.
Old 12-18-2003, 11:43 PM
youngvr4's Avatar
STREET RACING GURU
well i have heard of someone who was only at 12psi in there 1st gen with intake and exhaust and ran 12.9?
Old 12-19-2003, 12:40 AM
yup, and the vr4 spyder at 10psi on TD05 14b's that ran mid 11's. I think he was the second fastest car at NG03.
Old 12-19-2003, 11:33 AM
YogsVR4's Avatar
10 psi on a spyder that ran mid 11s even with those trubos? You sure about that?
In any case, the original poster said he got the mid 12s before he had most of those mods. Sorry, but the 9bs with a bad launch along with a passenger is not going to be anywhere close to the 12s.
Old 12-19-2003, 02:11 PM
yes im sure about the 11 sec run, its the reason "TD05 is god" lol
I dont expect to many people to be seeing those times tho. And your very correct about the 9bs in mid 12's
Old 12-19-2003, 07:14 PM
2of9 2of9 is offline
man, VR4's are quick...i thought with 500+ hp the VR4 would hit high 10s?? with jus a couple mods, the VR4 can already go mid/high 12 and 13s...well...thats what i heard...
I want a VR4...
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-19-2003, 10:27 PM
With 500+ wheel hp its posible to hit high 10's, but thats with a good driver. And with AWD it requires more HP to have that much WHP.
any my mistake, that spyder was on 11psi not 10psi when it made the 11.5ish run.
Old 12-20-2003, 08:31 PM
youngvr4's Avatar
STREET RACING GURU
I want a VR4...
yes they are easily upgraded but once you get into the 10's it kinda stops there, no one has took out the time to do what you need to do to run 9 anything. if i'm not mistakin there's a 700hp vr4 that runs like 10.4
or somethin like that, which is why it would be hard to run 10's with 500hp. i don't know what my 1/4 is but i'm dang near 400hp and i know i'm not even in the 11's so 500 should place you right there in the 11's
i'l be at around 400+once i drop this downpipe and get my super afc II.
it takes some blood sweat and tears to get them to run low 10's.
Old 12-22-2003, 07:33 PM
ikOnone ikOnone is offline
who said he was on the stockers, 13G's at 14psi should get you 12.5's pretty easy. and it is not like it is impossible to get those on the stockers anyway. there is a decent amount of people that get into the 12's bpu, just got to have the car in good tune, have a good driver, and be at or near sea level.
as far as that spyder goes... damn! i think i heard about that but i did not know it was at 11 psi. man i want 16G's sooooo bad.
as far as this car goes, yea, i would be cautious. but if all of those mods are in it, damn, i would still pay at least $8k for it. just buy some DR stage 3 heads and be on your way with a kick ass car
3000GT SL hp overated 300GTkid 3000GT/Stealth 9 02-07-2009 04:25 AM
new to 3000gts, gotta few questions. blackcell3 3000GT/Stealth 15 09-06-2007 04:28 PM
bad belts effect speed/HP???? Pulowski22_7 3000GT/Stealth 13 12-30-2004 12:41 PM
hp Question and cam question Pimpdady753 Performance 6 11-24-2004 08:32 AM
DX 4 speed HP jackacc '88 - '91 Civic | CRX | Wagon | Shuttlee 7 06-08-2003 10:35 PM
