| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
i have a 1990 GT 5.0, im kind of new with cars im just getting in to them because i have this nice car now, and i want to go fast. my gt has a cold air intake flow master exaust, and Headers. i was woundering how much hp do you think i am putting out. Also how hard is it to upgrade the pulles and cam. do i have to take the hole enging out, or what. thanks.
Re: hp Question and cam question
I suppose I can answer those:
You're probably making about 240hp at the crank. Pullies are easy, Cam is hard
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT. |
Start simple, intake manifold, throttle body, MAF, ETC. Gears are a good SOTP increase, but I would recommend having a shop do them if it's your first...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons..... http://www.cardomain.com/id/mccobra94 1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster. Freedom Isn't Free. |
i wouldnt worry w/ the cam if your gonan keep the car in mostly stock form. if your plannen on going all out and getting heads and intakes then it would be totally necessary to swap the cam. ive never changed pullies but it cant be too difficult.
God said RWD, and all the little torque lovers of the world said, AMEN!!
Replacing the pullies isn't too bad, the only problem I ran into was lining up the water pump pulley bolts. Make sure you put some penetrating oil on the alt pulley to loosen up some of the grime, it may take a impact gun to remove it but if you work on it with a breaker bar and a mallet (like I did) it'll come off sooner or later. Also loctite the crank pulley bolts.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt. |
ic i already have air intake and headers and flowmasters.
I wasn't talking about Cold Air, I meant an Edelbrock, GT-40/Cobra/explorer, Holley, or TFS Intake Manifold.
Stock cam outflows your heads, so don't swap cams with stock heads. You may actually lose power.
