Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 12-14-2003, 09:09 PM
bobalobagous bobalobagous is offline
Send a message via AIM to bobalobagous
Check/fill plug on MKIII manual trans
I know this sounds sad I can't find it, but I need help finding the check/fill plug for fluid on a '94 jetta 2.0 with manual tranny. I have the Hayne's manual and it says it should be on the differential casing and look like a hex bolt or something similar, close to the tranny ID number. I see the ID number, but no plug. The only hole to the tranny I've found is on the top of the bell-housing, and it's a plastic plug(what is this by the way?). Thanks to anyone that could help.
Old 01-31-2004, 03:25 PM
mmichalak mmichalak is offline
the check/fill plug is on the right hand side of the motor, at the rear of the tranny, you will have to remove the plastic splashguard (it just pulls off), i believe that the socket it a 17mm hex, its not a bolt. its a hex plug.
Re: Check/fill plug on MKIII manual trans
sorry i meant left hand side, the drivers side
Old 01-31-2004, 10:26 PM
ehsrifledude ehsrifledude is offline
damn... I've been searching for that like forever too. Hahaha
Old 02-03-2004, 09:07 PM
mmichalak i checked where you said and i think i know what you're talking about, but it's at the end of the transmission, not on the differential casing like the hayne's book says, the only hex plug i can find theere in on the very bottom facing the ground, so i figure it isn't for fluids. It's seriously pathetic i can't find it but transmission fluid is crucial so i'll keep trying. Write back if you have any more advice. Thanks.
'02 PT Cruiser Manual trans- won't go into gear win_daddy PT Cruiser | PT Cruiser Convertible 0 08-17-2010 01:30 PM
2006 4.2L Manual Trans. redka88 F Series 2 01-04-2010 08:51 PM
98 Manual Trans - Transmission Overhaul steveryd ZX2 3 06-30-2009 05:05 AM
5sp Manual tranny FILL PLUG????? gungadin Metro 4 08-26-2006 07:05 PM
where's the tranmission oil fill plug for escort 93 Manual ? iloverx100 Escort 14 09-25-2004 10:50 PM
