Old 01-03-2010, 01:41 PM
redka88 redka88 is offline
2006 4.2L Manual Trans.
Seems as the "fork" isnt disengaging all the way. only when its under 25 degrees F.
Proper bleeding procedure if there is one for the clutch??
Hoping not to have to replace slave cylinder.
Old 01-03-2010, 03:07 PM
mechhound mechhound is offline
Re: 2006 4.2L Manual Trans.
Have you checked the fluid level in your clutch master cylinder? Don't forget to remove that rubber cup(diaphram) under the cap when checking or adding fluid. I believe these still take dot 3 brake fluid, but check your owners manual.
As far as bleeding, I like to just gravity bleed them. Open the bleeder screw down on the master cylinder and let the fluid flow. Leave the top and diaphram off the master cylinder during the bleeding so you don't create a vacuum lock. Never let the master cylinder go dry during the procedure. Let about 12 ounces of fluid flow through, again never letting the master cylinder go dry, close up the bleeder screw, top up the master cylinder to the correct level and replace the diaphram and cap.
Old 01-04-2010, 08:51 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Could be a slave or through-out bearing. Sounds like you need a slave... sorry.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Tags
4.2 , clutch , disengage , manual , transmission
