Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-10-2003, 12:53 PM
k_dawg k_dawg is offline
B16 turbo
I have a B16a engine that I bought from JDM. I was wondering what the best kind of turbo to buy for it. DDo I have to do anything to the engine to not destroy the motor if I put the turbo on it? What all do I need to do? Thanks a lot
Old 12-10-2003, 03:07 PM
DarkEternal's Avatar
DarkEternal DarkEternal is offline
Re: B16 turbo
I don't know everything about turbos, so you'll want a second opinion, but; Turbonetics, Greddy, ApexI, and Blitz all have excellent turbos. The best turbo to buy is all up to how much power you want and how much turbo lag you're willing to endure. Smaller turbos, such as a T3, will give you a decent boost and you won't have much turbo lag. Larger turbos, such as a T24 or T66, will give you massive power gains but horrible turbo lag. For a street car/daily driver, I'd go with a T3/T4 hybrid. you'll get the larger compression of a T4 with the shorter spool-up time of a T3. As far as motor health goes, there's several things you should do. I'd start with rebuilding the motor and putting in forged internals, while you're at it, you might as well bore it out to a 1.8. Make sure your intercooler is the proper size and front mounted. Get a turbo timer and set it to 1-2 minutes. Keep an eye on your boost, vac/pressure, and oil temperature. You probably don't want your boost set higher than 8 or 10psi. If you don't forge your internals, you probably don't want your boost higher than 6psi. That should take care of you . If I've missed something or I'm wrong on something, feel free to correct me, anybody.
'93 Del Sol Si
D16z6
APC short ram intake
K&N Air Filter
APC strut bar
APC Performance muffler
generic breathers
ACT Stage 1 Racing Clutch
---~things to come~---
I'm not tellin'....
B16 Turbo question?? Joseph1082 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-28-2004 01:06 PM
B16 turbo questions k_dawg Let's get Technical! 5 04-20-2004 09:45 PM
B16 Turbo, what shot of NOS to use??? b16_beast Let's get Technical! 21 03-12-2004 09:32 PM
b16 turbo fuel questions maxspeedhonda Forced Induction 2 07-31-2003 02:30 PM
d16turbo to B16 turbo hondatool Forced Induction 9 03-10-2003 06:15 PM
