Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-19-2004, 09:49 PM
k_dawg k_dawg is offline
B16 turbo questions
I am putting a T3 on my B16 and have a couple of questions. I was wondering what computer would be a good fit for this turbo. I was also wondering if a fuel pressure regulator, injectors, or fuel pump would be a good choice. Please let me know as soon as possible, because I want to get this done. I also want as many replies as I can.
Old 04-19-2004, 11:33 PM
MexSiR's Avatar
MexSiR MexSiR is offline
Send a message via MSN to MexSiR
Re: B16 turbo questions
Depens on how much your going to boost. If you are boosting more lbs than lets say 6 (estimate) yes your injectors have to be upgradded along with the fuel pump. Computers as in chip ecu? Or VAFC controler...
Honda Civic 1999 EBP SiR
Im not as fast as I am furious.
1/4 mile = 15.347 (sealevel)
Porsche RS America
BMW 323 01
Pictures of my ride (Pictures)
Old 04-20-2004, 11:03 AM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
You going to use this car as a race car?
T3 is a small turbo and if you plan on being on the highway you will most likely spool 2-3 lbs at 80 MPH. 30 minutes of that and bye bye B16
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 04-20-2004, 06:22 PM
boosted331 boosted331 is offline
What the hell are you talking about? His turbo isn't going to make any boost if his motor isn't under load, and low throttle in 5th gear is not going to load the motor nearly enough to make boost.
Old 04-20-2004, 09:12 PM
If I am planning on running 7 PSI what size injectors should I get and also fuel pump. Should I also get a fuel pressure regulator or what? I don't see how I would blow up the engine going down the highway. But anyway anymore suggestionsa would be great. I don't want this thing to destroy my engine. Thanks a lot
Old 04-20-2004, 09:45 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
And to add to what Boosted331 said, saying T3 in and of itself is irrelevent, the turbine, and the compressor side BOTH need to be taken into consideration when sizing a turbo.
