Old 12-09-2003, 03:45 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Mandrel Bent vs Crush Bent
I know all the bigwig companies have mandrel bent exhaust sytems for smooth flow, but think about crush bent for a second. Picture a marching band or something, how they make those right/left turns all lined up straight. Well, the guys on the inside apex of the turn walk slower, while the outside ones walk faster, all keeping a straight line while exiting and going straight.
Now picture the airflow in an exhaust slowing down along the crinkles on the inside of a piping turn while the smooth side helps the outside gas keep up, and form a "straight line" on the exit, packing a full punch coming out the exhaust. I don't know, just a thought.
Old 12-09-2003, 03:52 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
is this just for newbies? of was there a story associated with this.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-09-2003, 03:57 PM
Ricochet's Avatar
Banned
Re: Mandrel Bent vs Crush Bent
no story, just sharing my thoughts. I know either way it's probably a difference of .0001 hp anyways... what u guys think?
Old 12-09-2003, 03:58 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
[Quoting The Matrix] He doesn't know [Quoting The Matrix]
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 12-09-2003, 04:02 PM
crxlvr's Avatar
as far as ive read mandrel bent piping always performs better than crush bent.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 12-10-2003, 05:18 AM
Milliardo's Avatar
Milliardo Milliardo is offline
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb
You might have something here. I'm reading up on the comparisons of headers for the D-series, found here: http://www.hadamotorsport.com/tech/review/dsemc/ Interesting in that one header design seems to feature a sort-of restriction. This is a stepped primary, found in the the Hedman Chikara 4-2-1 two-piece header. Note that the stepped primaries are not accidental restriction points, but are actually incorporated in the design. How are they restriction points? The pipe widens and then goes back to its original diameter, sort of like how the crinkles in crush bent pipes are. Strangely enough, this produces an improvement in velocity, as Ricochet noted. I'm not an engineer, so I really wouldn't know. Perhaps further tests might rethink the use of mandrel bent pipes and go back to a more older method of pipe bending.
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Old 12-10-2003, 07:27 PM
F23A4Racer750IL F23A4Racer750IL is offline
i dunno i would rather have the smoother flow vs the rougher even if there aint much of a hp difference. i think if the big time companies thought crush bent was better they would offer them.
Old 12-10-2003, 11:44 PM
BullShifter's Avatar
Re: Re: Mandrel Bent vs Crush Bent
eleventeen HP's
The best exhaust is made from that ghetto flex pipe from parts stores
Old 12-13-2003, 04:56 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Air does not quite move that way. When you are talking about how air is moving inside a piping, it's all about the degree of angle the pipe is made and the surface of the pipe inside where the air is "riding" on.
It is not the smoothest surface best when you are trying to make the air turn, it has to have a certain finish on the surface for the air to "grab" on the wall and turn on top of the degree of angle.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 12-14-2003, 12:15 AM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
the stepped headers are for improved velocity. After the exhaust exist the combustion chamber, it needs velocity too make it out the end of the pipes. Thus the step headers......they gradually get larger (usually three step) to get the exhaust out of the combustion chamber, then they get smaller to increase the velocity of the exhaust and allow it to exit the pipes. It has a lot to do with scavenging and the pulses of the exhaust (which i wont get into cuz thats another long story).
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 12-14-2003, 03:30 PM
Ricochet's Avatar
Banned
Wrong, exhausts get larger towards the muffler. Heat expands, and with larger diameter piping towards the end that makes it the only way to go.
Old 12-16-2003, 01:36 PM
No i'm not wrong. What i described is the ideal header/exhaust design for scavanging and tuning the exhaust pulses. Pipes don't get larger towards the exit. Yes, as temperature increases so does pressure. But what you described makes no sence. The further the exhaust gets down the pipe, the cooler it gets, so there is no need for the pipe to get larger. It looses pressure as it gets down the pipe. Besides everthing i was talking about was involved in the primary and secondary section of the header, not the pipes.
Old 12-16-2003, 01:40 PM
*i meant it looses temperature as it gets down the pipe, not pressure.
Old 12-19-2003, 09:54 PM
jweller jweller is offline
this guy is right.
exhaust velocity is king. go take a look at any length of pipe with a crush bend and think about how it would flow. it's going to be turbulent as sh!t at the bends. turbulence kills velocity
the stepped headers also help prevent reversion.
'94 silverado HD2500 3/4t 4X4 bent frame y13supio Silverado 3 03-05-2010 11:53 AM
crush vs. mandrel piping Chiquae07 Non Specific 16 03-25-2007 01:11 AM
mandrel bent or not? thebobs Prelude 10 02-04-2003 04:36 PM
mandrell bent or no? khead717 Engineering/ Technical 2 02-14-2002 09:10 AM
OEM exhaust mandrel bent ??? NismoPC Engine 8 10-25-2001 09:03 AM
