Hello all, My 200 Blazer won't go into 4 WD now for some reason....the other day a dash light came on that said "Service 4WD" and since then if I press either the Auto 4WD or the 4Hi buttons they just blink on and off and it never goes in. Does anyone have any idea if this is a common problem with an easy fix ? We're getting snow this weekend and my dealer appointment isn't until Monday so I'd like to fix it myself.
Thanks !
2005 Chevrolet Silverado 2500HD Ext cab |
Re: 2000 Blazer won't go into 4WD....Help !!
I belive it works off of vacume, check under the trammison and aroud it for any disconnected lines or elect. connections? Good Luck.
I was having the same problem with my 97 Blazer. The vacuum switch located on top of the transfer case was shot. It has three small vacuum lines on the receiving end and the other end has a ball bearing that gets worn out. $15-$30 for the part (I paid $30 but noticed others in this forum have only paid $15. I'm now having problems with the dashboard controls, but the vacuum switch needed to be replaced regardless.
they are known for the vacum switches and also the mode switch on the dash.
Have you tryed reseting the computor by unhooking the battery for 5 min. I don't know what this doe's but when I do this on My 92 the four wheel drive will go onto four high Old fart told me to do this it works
The vacuum switch is located on top of the transfer case, so you can't actually see it, but rather you have to reach around from underneath. On my model (1997) the 4wd transfer case closer to the driver side of the vehicle -- almost directly below the where the right leg would be if you were driving, if it helps to think of it in those terms.
It's a somewhat cumbersome fix because of the lack of wiggle room. I had so little room that I was unable to get enough leverage to work a socket wrench so I removed the driver seat, pealed away the carpet and drilled a hole just in front of the seat bolt and to the right by the stick shift to get at it. |
Re: Re: 2000 Blazer won't go into 4WD....Help !!
Just got my Blazer back.......for all who said vacuum switch......Ding !Ding ! Ding ! .....we have a winner !!!!
Question.... How much did this little job cost you? I am having the EXACT same problem and want to be prepared for the damage...;o) |
I replaced the vacuum switch on my 1991 a couple of weeks ago. I had to go to a dealership to get it. It cost $33.00 and takes 5 minutes ot replace. A bit tough to get to, but I wouldn't have paid anyone $100.00!!! What kind of warranty has this deductible? Extended warranties are always a rip off!
Re: You just got burned!!!
a 2000 blazer does not have a vacume switch on the transfercase
it is on the firewall above the coil,, check to make sure the line does not have a hole in it,, then on the right kick panel when you hit the button do you here a click?? |
