Old 07-22-2003, 03:02 PM
chevelle chevelle is offline
Angry Blazer shifting into 4WD Low by itself
My 2001 Blazer shifts into 4WD Low all by itself. The dealer has not been able to re-create the problem and has advised me to tow it in when it happens again. Has anyone heard of this before? What could possibly be the problem? The switch itself? What is the cure?
Old 07-25-2003, 10:14 AM
somoney7 somoney7 is offline
Hi Chevelle,
I had the same problem about a month ago. The dealer ended up replacing the 4WD module. In the meantime to make it driveable, once you shift it into 2WD remove fuse 15. I think its 15, check the back of the cover to the fuse box. This will allow you to drive without the 4WD system powered up. It shouldn't switch automatically anymore, but you also lose your fuel gauge indication so make sure you know how far you can drive.
Old 07-25-2003, 10:47 AM
Thanks for the reply somoney7. The dealer has told to me return the vehicle when it happens again. Do you recall where the 4WD module is located? Did you have yours towed in? Just curious how your dealer found the problem. I have heard from other Blazer owners of this same problem. The remedies have been the switch and the wiring harness to the trans.. This is the first time I have heard about a 4WD module.
Thanks again
Old 07-25-2003, 12:22 PM
It is fuse 15 and it's labled 4WD, I checked. I had it shift on me while I was visiting my mom in San Diego. Luckily one of the dealers in town had their service department open. I figured out that once I shifted in to 2WD I could remove power to the 4WD system by removing fuse 15. Once I did that, I drove to the dealer and he told me about the 4WD control module and the switch. He only had the module in stock so that was changed out. I still haven't changed out the switch but it drives fine. Sorry but I'm not sure where the 4WD control module is located, but I hope some of this information helps.
good luck.
Old 07-25-2003, 12:48 PM
Thanks again somoney7. Your info really does help. I know first hand how difficult in can be to repair something which doesn't happen all the time. From the responses I have had here and on another forum, this seems to be a common problem. Good luck with yours and please let me know if it happens again.
Old 07-25-2003, 01:07 PM
Did you see this
http://www.automotiveforums.com/vbulletin/t94447.html
Old 07-25-2003, 01:15 PM
Wow, thanks again. I didn't see that. I guess that answers a couple of questions.
1. Where it's at
2. Cost $600 bucks????
Good thing I have a warranty. I just hope this gets resolved before it ends.
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
2000 Blazer Shifting Into 4WD On Its Own While Driving. jimgunthorpe Problem Diagnosis 3 02-04-2009 10:20 AM
1987 blazer grinding when shifting into 4wd lo black9label9 Problem Diagnosis 1 12-03-2008 05:29 PM
Can't shift into 4WD LOW only fouroneone Suburban 5 02-12-2008 04:56 PM
98 Blazer-Will not go into 4wd Low drw170 Blazer 5 04-29-2006 05:37 PM
