Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 12-02-2003, 10:50 AM
buchhorn buchhorn is offline
Unhappy HELP!!! AC only works when the break is applied
I have a 2000 plymouth neon that the ac only works whne i apply the break. i have checked all fuses, relays, wiring and switches. I have swapped out parts and still have no resolution. For some reason everytim o hit the breaks the ac will work as designed. I can disconnect teh break switch and the ac works as designed, but i have no break lights then. Any one else ever have this issue? The dealership could not find any errors on the computer and had no error codes. I have swapped aout the break switches, air switches, fuses and relays and still no resolution. Any suggestions or advise will be greatly appreciated. You can replay directly to me at [email protected] or [email protected].
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on amikayla Montana/Montana SV6 1 06-01-2010 12:25 PM
horn does not work replaced control module . works when the alarm is turned on Help?? mms531 Rodeo | Passport | MU 3 03-09-2007 11:36 AM
Help! my horn only works when it feels like it digimon Caravan | Voyager 4 01-23-2005 01:43 PM
A/C Only works when it is below 98 Degrees 98328i 3 Series 4 08-26-2003 03:47 PM
Turn signals only work when car is warm?!? Marc-OS Engineering/ Technical 2 05-14-2002 10:56 PM
