Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-08-2007, 08:58 PM
mms531 mms531 is offline
horn does not work replaced control module . works when the alarm is turned on Help??
Horn is not working I can't seem to figure this out ?
Old 03-08-2007, 10:56 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: horn does not work replaced control module . works when the alarm is turned on Help??
Probably the horn its self is bad or one of the fuses. You dont say what year yours is but I know on 98+ rodeos there is a seperate horn for the alarm system located on the passenger inner fender behind the ABS module. The main horn is on the front of the radiator support behind the grill. I think there is one fuse in the dash fuse block and one under the hood for the horn but done remember.
I replaced my horn with some Fiamm dual air horns. Much louder and sounds like a european sports car horn.
I also replaced the alarm horn with an american car sounding horn, also from Fiamm.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 03-08-2007, 11:23 PM
trooperbc's Avatar
trooperbc trooperbc is offline
what year? what have you done so far? what have you checked? it could be a number of things in the circuit -- horn contact at the steering wheel? horn relay? horn itself? associated wiring? have checked any or all of those so far?
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 03-09-2007, 11:36 AM
I have a 2001 rodeo 4x4 I checked all the fuses in the block under the hood and in the dash but I did not know that there was two horns one for the alarm and one for the horn thank you I appriciate the help.
