Old 12-01-2003, 03:10 AM
portaman03 portaman03 is offline
Send a message via AIM to portaman03 Send a message via Yahoo to portaman03
Installing a grounding kit
hey i just purchased a R1 grounding kit for my 94 accord. its almost identical to the HKS Circle Earth kit priced for hundreds more. anyway, it didnt come with instructions. can anyone help out with installation? thanks.
Old 12-03-2003, 02:03 AM
cuba3377's Avatar
cuba3377 cuba3377 is offline
Re: Installing a grounding kit
its sorta just plug and play. enuf said ^ ^
94 INTEGRA NEVER LOOKED SO GOOD ^^
Old 12-03-2003, 02:11 AM
yea, but should i attach the provided terminal clamp and then attach to any random grounding areas?? or are there specific areas to ground with?? or would it be better to find factory ground wires and replace them with the aftermarket ones??
Old 12-03-2003, 02:18 AM
cuba3377's Avatar
lol
depends on the quality of the terminal clamps. what are they made of????
BTW, stick with oem grounding areas. normally there just a bolt with a fish eye. if your looking for a good tip. get a metal brush, when you remove the bolts, and clean the mating surface of the bolt, and the body. rust tends to build, causeing resistance. if you are REALLY serious about low resistance in your car, get a digital multimeter, and check your work.
Old 12-03-2003, 02:19 AM
werd thanx
Old 12-03-2003, 01:55 PM
Mendari Mendari is offline
Unless you have a multi-tester and know how to use it, I wouldn't proceed with the installation. How strong is your understanding of electrical current?
Grounding kit install 94 Honda Accord djchiena Accord/TSX/Accord Hybrid 8 12-07-2003 04:01 PM
Installing a grounding kit portaman03 Street Racing 0 12-01-2003 02:56 AM
Pt.2 Problems installing Ground Controls! Pics inside!! LX98Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 04-04-2002 07:24 AM
Problems installing Ground Controls! Pics inside!! LX98Civic Tires and Wheels 6 04-03-2002 02:50 PM
Problems installing Ground Controls! Pics inside!! LX98Civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 03-31-2002 02:57 PM
