Old 11-29-2003, 04:24 PM
rhoads1202 rhoads1202 is offline
Exclamation Gas Tank
Anyone know how to remove the gas tank on a 1999 Chevy Suburban so I can change the fuel pump?
Old 12-02-2003, 02:41 AM
blueburbboober blueburbboober is offline
chiltons walks you right through it. pretty much, jack the burb up real high. support the tank with a hydraulic jack. (oh yeah, syphen out the gas, it sucks if there is gas in it.) unbolt the guards and straps that hold the tank. SLOWLY let down the tank using the jack. then using a couple wrenches undo the high pressure lines. undo the breather lines. theres a wiring harness that unclips somewhere along the chassis. the harness does NOT come undone right at the tank. its hard to see, but trust me, theres nothing to undo right at the tank, follow the wires till you find the clip. it is about 1.5 feet away. then lower it down. the rest is cake. you just use a brass punch to spin the ring that holds the pump in, carefully pull it out, and the rest is all she bang. pretty simple really, just follow your instincts. itll take you 3-4 hours if its your first time, so plan for it.
-Rob
No more burb for me!!
2005 Jeep Wrangler. Blue, 4.0L
2004 Jeep Wrangler Unlimited. Bright green, 4.0L. No mods yet on either!
Old 12-02-2003, 06:49 AM
jfmctlaw jfmctlaw is offline
Re: Gas Tank
Don't forget to deal with the filler neck. Make sure you take off the gas cap. Make sure the tank is empty. Also realize that an empty tank is the most dangerous tank in terms of a possible explosion (a full tank can't explode). No sparks, flames or cigarettes allowed anywhere in the vicinity of your job.
Gas tank fill tube leak DavidLang Metro 4 12-02-2010 06:08 PM
how to replace a gas tank chrisl757 FYI - How to... 3 12-29-2009 07:34 AM
Added gas mixed w/oil into my gas tank...what can I do? CldYngThug0518 Cavalier Problem Diagnosis 3 10-11-2005 12:41 PM
Gas Odour / Gas Tank Replacement bigaldover Blazer 2 05-22-2005 02:29 PM
91 GT-S Hole in gas tank, can't find tank.. help Decoy Celica 8 04-28-2005 08:25 PM
