Old 11-26-2010, 03:56 PM
DavidLang's Avatar
DavidLang DavidLang is offline
Gas tank fill tube leak
2K Metro has a hole in the gasoline tank fill tube, between the gas cap and tank. It doesn't leak only when putting gas in. Is this hard to change or patch? Anyone have this before?
I just found a replacement fuel filler neck. Is this hard to change. Can you change it with gas in the tank if you're careful?
Thanks for any and all advise.
Old 11-26-2010, 05:27 PM
Rooy Rooy is offline
Re: Gas tank fill tube leak
Very common problem on all Metros, especially where road salt is used. Patching it might work if it's not too far gone. You'll have to take it off and see. It has a plastic coating, that once breached, traps moisture and allows rust to thrive, so it can be worse than it looks at first.
fillnernecksupply.com has new ones, but their webstore appears to be down. They're about $90 though.
You could go junkyard hunting and hope you find a rust-free one.
Or you could make one: http://geometroforum.com/topic/3546230
They're not too hard to change. You should be able to change it with gas in the tank, depending on how much there is. How full is it? Having the rear jacked up will help. I'm thinking 3/4 tank or less would be ideal.
Old 11-26-2010, 06:01 PM
DavidLang's Avatar
Thanks Rooy! I just bought a used replacement on Ebay after reading your post. Great help!
I'm hoping it is pretty obvious what I need to do in changing it. Looks like some 50 degree weather heading this way which will help.
Thanks again.
Old 11-26-2010, 06:09 PM
It's pretty straightforward. 3 or 4 bolts inside the gas tank door. They might be stuck/rusty so use some penetrating oil so you don't snap them off. There's also one hanger bolt on the bottom holding the end of the tube.
Old 12-02-2010, 06:08 PM
DavidLang's Avatar
Smile Re: Gas tank fill tube leak
A guy at my oil change place replaced the bad tube with the one I found on Ebay. The leaking one was far worse than I thought. He only charged about $60.
I don't know what to do when our Metros finally give out. There's nothing out there to replace them with as far as I can see. I'd sure like to see the XFI re-issued.
D.
how to replace a gas tank chrisl757 FYI - How to... 3 12-29-2009 07:34 AM
Camry gas tank filling problems patalyssa Camry/Camry Hybrid/Vista 5 11-18-2006 11:25 PM
'87 944 Oil fill tube leak Guillaume01 924/944/968 0 10-24-2005 02:25 PM
92 Camry Gas Tank Fill Tube MTrachy Camry/Camry Hybrid/Vista 1 10-13-2005 11:50 PM
Taurus gas tank filling problems tula771 Taurus | Taurus Wagon 6 08-08-2005 02:56 AM
Tags
gas , leaks , tank , tube
