Old 11-20-2003, 03:58 PM
Slacky Slacky is offline
Send a message via AIM to Slacky
90 REX B16 antifreeze leak
Gotta a leak that looks like its near the radiator, but I can see some coolant on the bottom of the tranny, where do you guys think it's leaking, I don't have time to take it apart right now, hopefully its the lower hose, but I don't know....
Brian
Old 11-20-2003, 09:46 PM
Now, after getting in an accident in my friends transam, i found out what is happening with my car. I filled it up with coolant, ran it till it started to overheat, then shut it down, after that a ton of antifreeze came pouring out under the radiator. What is wrong? Radiator, lower hose? I know there's a build up of pressure, but I need some help? Please tell me!!!
Old 11-21-2003, 02:44 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
there could be a number of problems. First take the rad. cap off and see it there are any bubbles coming out. Second check all the hoses for cracks, also check to see if the over flow is where the fluid is coming from. Third check the lower section of the rad. to see if there are any cracks or holes. If you dont find anything the throw some Bards (spelling) rad. stop leak in it and continue to drive. My thoughts.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 11-21-2003, 09:52 AM
There were a few bubbles, but not enough to say the coolant was flowing, although I couldn't get the car to overheat this time. But it still dumped the antifreeze after it shut off. As far as I can see no cracks on hoses, although if there would be cracks it would leak the whole time, not when I shut the car off. I can't see the lower section of the rad, the frames in the way under the car, and you can't see shit from above. It's either the radiator leaking, or the lower hose. As for why it's doing this I don't know, I'm lost.....
Old 04-21-2004, 11:08 AM
PaSleeper PaSleeper is offline
Re: 90 REX B16 antifreeze leak
Have you had someone else turn the car off while you watched to see where the antifreeze is coming from when it is dumped? My radiator was leaking from the lower hose, which wasnt cracked, just needed to be re-aligned and re-tightened at its connection to the radiator. I dont know how it works in a crx but my si radiator was very easy to take out and inspect. good luck
Antifreeze odor & leak Silvio99 Tahoe 3 10-27-2010 11:19 AM
1994 Olds Achieva, 3.1 S Leaking coolant rastaron Achieva 1 09-23-2010 11:13 AM
Antifreeze leaking INTO car.. Tom_Servo Stratus 4 08-24-2004 08:52 PM
Antifreeze leak rds190 Stratus 4 06-11-2004 08:16 PM
1997 grand am antifreeze leak coco345 Grand AM 1 03-07-2004 08:23 PM
