Old 03-07-2004, 07:08 PM
coco345 coco345 is offline
1997 grand am antifreeze leak
I am trying to stop an antifreeze leak on a 1997 Grand Am (3.1 liter) It appears the fluid is running down from the top hole in the water pump housing on the left side of the engine, I have changed the gasket twice, and the fluid seems to be coming from the same place each time. I've put new bolts in, used silicone sealant on the gasket, also teflon sealant on the bolt threads, to no avail. I'm not sure if there may be a hair line crack in the housing, and or block. Any help on this would be deeply appreciated. I've spent about 4 days on this project and it is driving me crazy!!!!!
Old 03-07-2004, 08:23 PM
blueplayer blueplayer is offline
Well there very well culd be a hairline in either of those did the car overheat at anytimr b4 this?? Did you put the bolts in at thier torque specs???? this could be your prob if to tight could damage the gasket if to loose might not make a good seal....
good luck....
bp
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
1997 Ford Taurus GL Antifreeze Leak Shad Claiborne Taurus | Taurus Wagon 6 03-04-2008 10:54 PM
97 Grand Am Leak Antifreeze Pass. Side 94pauone Grand AM 4 02-21-2007 05:05 PM
98 grand am antifreeze leak madgootch Grand AM 8 11-13-2006 08:39 AM
1997 Grand Am leaking oil ereds5 Grand AM 1 01-15-2005 06:16 PM
