Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-26-2010, 08:40 AM
Silvio99 Silvio99 is offline
Antifreeze odor & leak
On my '05, V8 Tahoe with 64,000 miles, we noticed an distinct antifreeze smell the other day while driving. When we got home, we noticed antifreeze leaking (dripping) onto the rear tailpipe (passenger side). The leak was coming from above the tailpipe where two hoses quick-connect to what I assume to be the rear heater core located in the rear quarter panel. Question 1-Do those quick connectors have rubber seals that might have gone bad? Question 2-Or do you think it is the heater core gone bad? If it is the heater core, any advice on replacing it or is it a straight forward repair? Thanks!
Silvio
Old 10-26-2010, 10:22 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Antifreeze odor & leak
Quick connectors have rubber o rings in them.
We can not see or look t it for you so.
You need to find out for sure where it is leaking.
Before you can fix it.
Post back where it is leaking for help on it.
MT
Old 10-27-2010, 08:27 AM
j cAT j cAT is offline
Silvio
THESE hose connectors do leak, usually when improper tools used to remove from the heater core. remove these hoses and then with 10psi of air pressure leak test the heater core for holding pressure .
If no leaks replace these hoses or remove the quick disconnects and use hose clamps.
Old 10-27-2010, 11:19 AM
Scrapper Scrapper is offline
AF Premium User
you could take heater hoses off and bypass them by putting something in the midle of hoses and see if it's your heater core? you never got it hot did you? you can feel around your rug and see if it's it's wet also.
1994 Olds Achieva, 3.1 S Leaking coolant rastaron Achieva 1 09-23-2010 11:13 AM
98 Blazer antifreeze smell - no leaks? LAN2UNOW Problem Diagnosis 7 11-17-2008 08:17 AM
Antifreeze Smell, & Loss 1994RangerMan Ranger | Courier 19 10-15-2005 11:53 AM
95 bonneville antifreeze odor qball21 Bonneville 2 03-12-2005 01:59 PM
Tags
antifreeze , heatercore , leak , rear , tahoe
