Old 11-20-2003, 09:53 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Gains from cam sprockets?
I went to the shop I buy everything from and traded in my used n2o kit, DX cam sprocket, and crank pulley for a couple aem cam sprockets for my dohc (I couldn't sell my DX crap to anybody else, so I said screw it and gave it to them). Anyways, will I see any gains or will the car just run better? I'm hoping for 5-10hp at the wheels if possible. When I had the sprocket and pulley on my d16 I gained 6whp, but that was probably only from the pulley..? They're going to dynotune it etc. but I just wanna get some numbers beforehand from people who have already installed them on their dohcs..
Old 11-20-2003, 10:13 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Gains from cam sprockets?
Just switching out the cam gears won't do anything, you have to tune the intake and exhaust (more is going to be seen from the intake than the exhaust), but really, your motor is pretty well tuned fom Honda as it is a "sports car" motor, so without altering air/fuel, and ignition timing, gains won't be very large.
Old 11-20-2003, 10:17 AM
Ricochet's Avatar
Banned
Right, but they could make it so the valves open up at different times to have more air in there right? I've never messed w/sprockets or researched them enough to know exactly what they do..
Old 11-20-2003, 10:33 AM
Re: Re: Gains from cam sprockets?
The gears aren't going to make more air enter the cylinders (would need cam with higher lift, and longer duration), but they can adjust the relationship between in. and ex. valve opening and closing, via location of ones cam lobes in relation to the others, to maximize the amount that is in there.
Old 11-20-2003, 10:37 AM
Ricochet's Avatar
Banned
Re: Re: Re: Gains from cam sprockets?
Gotcha. Well when I get them in I'll scan and post the dyno charts for other people's reference to.
Old 11-20-2003, 06:19 PM
S1 Type-R's Avatar
S1 Type-R S1 Type-R is offline
Send a message via AIM to S1 Type-R
Lemme know how it does after they are installed....Im planning on getting some for my Type-R...
2001 ITR
WWW.SQUADONE.NET
Old 11-20-2003, 06:42 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Lightbulb
I don't know how in depth they go into tuning at the shop that you go to, but if you want the most power from your engine, there is a presice point at which maximum cylinder pressure should take place. If you can get your maximum cylinder pressure at 12 degrees past TDC, then you are in the zone for max power and effieciency. With you new cam gears, you can do some tuning to reach this point. You would also need to adjust your spark timming too. Ask the shop and see if they do anything like this....if they do, it would be well worth it; not only for power, but also the life of your engine.
Old 11-20-2003, 09:49 PM
Ricochet's Avatar
Banned
They know what they're doing. They ran my DX 3-4 times to get 6 more at the wheels, but that was with the pulley also. I don't think my scanner works so hopefully they can email me the dynochart..
FS Cams + WRP Variable Exhaust Cam Sprocket ProZach626 Sentra | 200SX (USDM FWD) 3 01-09-2008 03:19 PM
cam sprockets jgillis Caravan | Voyager 6 02-21-2005 04:54 AM
Better Gains from Stage 2 Heads/Cam or an intercooler? jeffs_GTP_sleeper Grand Prix 3 06-06-2004 02:45 PM
Cam Sprocket on SOHC Turbo? Frostbyte Forced Induction 1 10-16-2002 12:59 PM
SOHC Cam Sprocket Advance or Retard? Frostbyte Engineering/ Technical 15 10-11-2002 10:51 AM
