Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-14-2002, 10:20 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Cam Sprocket on SOHC Turbo?
I was wondering if when I do get a Turbo if I do should I retard the Cam Sprocket all the time? or should leave it advanced like I have? I have a D16z6 motor. I may be getting the Turbonetics T04/T3 Turbo.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 10-16-2002, 01:59 PM
civicgsr_T4_60-1 civicgsr_T4_60-1 is offline
Send a message via AIM to civicgsr_T4_60-1
actually don't mess with it unless you put it on a dyno and can figure all things out. You don't want to do anything. When i first did my turbo sohc i retarded the cam timing but it sent my ignition timing to 19degrees which is not good. The shops race car doesnt even use that much timing. Put it on a dyno because no matter what anyone says her or anywhere else, they dyno is the only answer you want to listen to.
00 civic with bolt-ons, i swear
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
