Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-20-2003, 09:04 AM
barfly barfly is offline
Question Thermostat light Blinking and not stopping
My Girls 2002 Jetta has been acting up. The thermostat light will blink and not stop when first started. This is not something that happens all the time. Just every now and then. The engine is cold, not hot, and the thermostat gauge is showing a clold engine. I did not belive her untill is did it with me. I stoped and restarted the engine and that took care of it the first time, but the second time it did not cure my blink light. The dealership looked at it, but found nothing. Does not seem to be a problem once the engine warms up. Should I insist the Sending unit be replaced???? The gauge works fine, it just that darn light, and a beep noice every min or so. Anyone run into this before, or have a thread for me to refer to???
[email protected]
Old 12-06-2003, 12:27 PM
peterjbotelho peterjbotelho is offline
coolant temperature sensor
Check the coolant temperature sensor located on the gooseneck that connects the coolant to the engine. I had the same problem with my 89 jetta and replaced that part. It worked fine.
Old 12-06-2003, 01:24 PM
Re: Thermostat light Blinking and not stopping
I found the problem. The jetta was parked at an odd angle which then the car though the fluid was low. Oh well, stupid me shuld have figured that out. Thanks for the replys
Security alarm light blinking, will not start NotoriousHOP Ram Pickup | Ram SRT10 6 05-18-2016 09:10 AM
Airbag light blinks and cruise control not work! amplifier28 Econoline 6 03-17-2009 09:36 PM
ac light blinks and ac stops cooling. dia_cero2002 Malibu 1 07-17-2006 02:14 PM
SECURITY light blinking and not starting tecarstuf Grand AM 5 10-15-2005 10:55 PM
Oil pressure light blinks at a stop reli Golf 2 07-24-2005 12:37 PM
