Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-18-2006, 03:18 PM
NotoriousHOP NotoriousHOP is offline
Security alarm light blinking, will not start
It HAD to happen yesterday.
I've got a sick ritual where I wait until 9pm on tax day to START doing my taxes and then roll up to the post office around 11:30p to drop it off. Well this year is the last year I do that.
I got in my truck, put the key in the ignition, started turning it, all the lights on the dash turned on as usual and as I continued to start it, all the lights in the vehicle when out. Except for the red security alarm light blinking on my dashboard. Walked away for a few minutes and then came back to the truck. All the lights worked again until I tried to start it.
This is apparently the vehicle's built-in security system. Assuming no one was messing with my vehicle earlier that evening, what could have caused this to engage? Is there anything special about the key that could be causing this (key worn or some unknown security device in the chip)?
Is there any simple way to reset it or bypass it without significant effort? Does anyone have any suggestions for things I can try? If I have to take it into the dealer, what is the likely problem and cost to fix (looking for a reasonably educated estimate)? Any help anyone can provide would be appreciated. Thanks.
Rob
Old 04-18-2006, 10:13 PM
sneakybert sneakybert is offline
Re: Security alarm light blinking, will not start
What year of pick-up do you have ?
Old 04-18-2006, 10:33 PM
It's a 2002 Dodge Ram 1500 Quad Cab.
Old 04-18-2006, 11:57 PM
loganlott loganlott is offline
check your cables
2005 Chevy Z-71 Ext. Cab
2003 Dodge Ram SLT 4x4 Laramie QuadCab
2000 Chevy Camaro SS
Old 04-23-2006, 03:28 PM
KManiac's Avatar
KManiac KManiac is offline
You reset the "anti-theft" alarm by inserting the ignition key in the outside driver door lock, turn the key to lock, then turn the key to unlock. That is the only way.
I learned this the hard way with a rental car, a 1998 Chrysler Sebring Convertible. I parked the car with the top down and habitually locked the car with the power lock button as I exited the car. When I returned, I reached in and pulled up the door lock button. This set off the alarm. Thank God the owner's manual was in the glove compartment. It took me five minutes to finally find the information I needed to reset the alarm. Very embarassing!
The alarm will set whenever you lock the car either manually by lock button or power lock switch when a door is open and then you close the door; or by closing all doors and locking with a key in the driver door or using keyless remote lock button. Once the alarm is set, it expects the car to be unlocked either by keyless remote or a key from the outside.
When the system begins to arm, you will see the "security" light illuminate on the dashboard during a 30 second time delay. Once the light goes out, the system will be armed. Once set, the alarm will go off if a door is opened or unlocked from the inside or the you attempt to start the car without first unlocking the car from the outside.
I suggest you play with your alarm system so you know how it works and how to operate it.
I once played a dirty trick on my father one day in his 1998 Ram 1500 pick-up. As we are ready to leave to go somewhere, he opened the driver door and exited the truck to get something, leaving the driver door open. While seated in the truck, I pushed the power lock button and locked the doors. When he gets back in, he shuts the door and the security system starts it's time delay. Then he starts to play with this cell phone and then the system fully arms. He then puts the key in the ignition and trys the start the car. The alarm goes off and he sits there dumbfounded while I'm sitting in the passenger seat doubled over in laughter. That's the day he learned how his alarm system worked.
Recently, I rescued a poor fellow in this Mitsubishi Montero. He parked his car and sat in it a while, shuffling through papers in the front seat, or something like that. He opens his door and the alarm goes off. I watched him for about two minutes as he struggles with things inside the car and looking dumbfounded. I then walked over to him and told him to use his ignition key in the door lock. The alarm stopped. I then explained to him exactly what he did to set off the alarm. And he confirmed that I was dead-on correct. He then thanked me for showing him what to do in the future.
Good luck with this and let us know if you have any other questions.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 08-20-2009, 01:44 PM
kbettorf kbettorf is offline
What was the problem? My husband had the exact same thing happen to him this morning on his 2002 Dodge Ram. How did you fix it?
Old 05-18-2016, 09:10 AM
larrymagee67 larrymagee67 is offline
I bought my 2000 ram 1500 used ever since I've had it I've had to hit the unlock button on the remote to get the red light to stop blinking so I could crank it, but now I can't get the red light to quit flashing and it won't crank
