Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-19-2003, 12:37 PM
John Muro John Muro is offline
Crank pulley removal
My book says once the crankshaft bolt is removed the pulley can be removed by hand. Thats not happening. Should I try a gear puller, or there are three threaded holes I can get to threw the pulley and maybe get a steering wheel puller attached to. They look like part of the dampener. Already tried some heat to lossen it. thanks for any help!!
Old 11-19-2003, 05:31 PM
1995LSS 1995LSS is offline
I removed mine by tapping a 1/2 inch pipe thread in the center hole. I made a puller out of a 1\2 inch pipe plug & a 1\2 inch threaded bolt.
Old 11-20-2003, 06:43 AM
bridget36907's Avatar
bridget36907 bridget36907 is offline
Yes the manual does say it will come off by hand....but not I had to rent the pully from auto zone...not the crab type pne but the one that takes the 3 screws.....later
2005 Grand Prix GT
3800
1995 Chevy Caprice
LT1 5.7
1986 Dodge Ram
Old 11-20-2003, 08:34 AM
Thanks for the replies! In case this will help someone else I ended up using a steering wheel puller with three 3"x 1/4 fine threads threaded into three holes accessable through the slots in the pulley. thanks again John
Old 12-21-2003, 07:07 PM
Mpalze Mpalze is offline
Re: Crank pulley removal
Or, you could be like me, and pay $150 for a mechanic to replace it.
Old 12-24-2003, 08:34 PM
jkinney jkinney is offline
sounds like you were trying to remove the balancer.Your lucky, those are metric thread, M6 I believe - which is .24 inch X .8 pitch, you might have smoked the threads if you went in too far.
Old 01-17-2004, 08:54 PM
Bravo Garage Bravo Garage is offline
You can also use a 2 prong gear puller to remove the crank shaft pulley. With the center bolt loose, but not out, use the 2 prong gear puller. It will pop loose, then finish removing the center bolt.
Crank Pulley Removal rruddfan21 Metro 4 10-31-2005 04:00 PM
3.3 crank pulley removal. mustang Dan351 Century 9 09-08-2005 11:09 PM
95 esi crank pulley removal clancys95 Off-Topic 5 05-30-2005 06:06 PM
crank pulley removal coonass420 Engineering/ Technical 10 08-14-2002 10:38 PM
crank pulley removal RickDaTuner Engineering/ Technical 6 03-26-2002 08:22 AM
