Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-01-2003, 10:07 PM
mustang Dan351 mustang Dan351 is offline
Send a message via Yahoo to mustang Dan351
3.3 crank pulley removal.
does anyone have a tip or trick on how to remove the center bolt on the crank pulley .I need to replace the crank sensor . and I can not get the bolt loose.
Old 07-02-2003, 05:55 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
I imagine GM has a special tool for that, Flatrater will be able to help you when he checks back in.
Old 07-03-2003, 06:16 PM
pcv pcv is offline
Put an air gun to it. If it does not loosen up, warm the bolt to burn the locktite that is on the tread and try again. Once the bolt is out, you need a puller with 3 little, long bolts to screw into the harmonic ballancer and pull it out. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 07-03-2003, 09:36 PM
ok the bolt is out and I bought a puller but it has the wrong bolt w/the kit .are the bolt just SAE 1/4 28 or are they metric
Old 07-04-2003, 09:35 AM
pcv pcv is offline
The bolts will not be in the kit. You will have to go to a hardware store and buy 4 inch skinny metric bolts to fit the holes. There three little holes in the ballancer. Make sure they fit nice and easy, don't cross thread them. Get some big washers too to fit the new bolts. Use the puller and new bolts and pull the ballancer out. When installing the ballancer, make sure the new crank sensor cleas the crank pulley. Rotate the crank pulley by hand twice clockwise to make sure the sensor is clear and will not be damaged.
Let me know if you need any more info.
Old 10-20-2003, 03:15 PM
grapehead grapehead is offline
Re: 3.3 crank pulley removal.
does anyone know offhand what size bolts those are? and a good place to find them? a search of lowes and home depot turned up nothing long enough to work...
Old 10-22-2003, 07:24 AM
pcv pcv is offline
They are 4" long 6mm metric bolts, available at home depot. That's where I used to get them from. I am sure they are still available. However I'm not sure if it is 6mm or 8mm. None of my techs have them with them.
Good Luck.
Old 10-25-2003, 05:03 PM
Re: Re: 3.3 crank pulley removal.
yes. 6mm. got it all done now. thanks!
Old 10-29-2003, 02:16 PM
pcv pcv is offline
You are welcome.
Old 09-08-2005, 11:09 PM
dane_774 dane_774 is offline
im working on one right now there is no bolt holes there .you must use 2 pry bars or large scrue drivers and get on both sides .watch out for the crank sensor and wabble it off it is not pressed on like most cars .and good luck .p.s you must get the bolt tight putting it back on .i mean tight or you will lose your motor
Crank Pulley Removal rruddfan21 Metro 4 10-31-2005 04:00 PM
95 esi crank pulley removal clancys95 Off-Topic 5 05-30-2005 06:06 PM
Crank pulley removal John Muro Bonneville 6 01-17-2004 08:54 PM
crank pulley removal coonass420 Engineering/ Technical 10 08-14-2002 10:38 PM
crank pulley removal RickDaTuner Engineering/ Technical 6 03-26-2002 08:22 AM
